MDC Encode Problems
wv8mat
Letart, WV
I have several HT1250's and never had this problem, programmed a HT750 the same way and noticed a problem. We use push button talkaround and when the HT750 goes to talkaround the radio does not tx the MDC code. yet the HT1250's all do. On the repeater both radios will tx the MDC. any thoughts
CT22
Banned
CT
Check your programming...
DPH11
Sayre, PA
Wish I had a solution for you, but I am having the same issue with my EX600XLS...
RKG
Boston, MA
I'm not specifically familiar with the HT750, but traditionally MDC PTT-ID was intended to be transmitted only to a dispatch console, since until recently only dispatch consoles incorporated MDC decoders capable of decoding and displaying the PTT-ID. So it doesn't surprise me that a low-end radio would be firmware programmed to ignore PTT-ID when operating simplex.
wv8mat
Letart, WV
I just dont understand why the HT-1250 and HT-1550 will do it on Talkaround but the HT-750 doent
SOUTH300
Carencro, LA
Try programming a seperate channel as the talk around to that repeater, and make sure you set it to transmit the MDC ID on that channel. This will tell you if there is a problem with using the button as T/A as opposed to a seperate channel. Downfall is having to use a channel for a simplex to a repeater but it should work.
