3.2.20 Firmware Bug? CTCSS 2x setting
w6vny
I have discovered an odd CTCSS behavior after upgrading firmware to 3.2.20 on H series radios.
Upgraded a HP782 & HM782 from 3.1.01 to 3.2.20. After upgrade, every analog channel transmits the CTCSS tone at exactly 2× the frequency I program.
Testing & Troubleshooting:
Programmed 103.5 Hz → T-SQL scan shows 206.5 Hz
Programmed 100.0 Hz → T-SQL scan shows 199.5 Hz
Programmed 79.7 Hz → T-SQL scan shows 159.8 Hz
Carrier and voice audio are perfect monitoring input from another radio. The repeater simply never opens because it never sees the correct tone.
  • Brand-new analog channel created from scratch
  • Emp De-emp = unchecked
  • CTCSS Tail Revert = unchecked
  • TX Admit = Always Allow
  • RX CTCSS = None
  • Full write + power cycle after every change
  • Full write of default rcdx file, power cycle, configure analog channel
The exact same codeplug and channel settings worked perfectly on the previous firmware
Tried to downgrade to 3.1.01 but I get “The firmware version [A3.2.20.008] is beyond the upgrade software!”
Any thoughts?
