Mid-Air Refueling over Nova Scotia
krw
Scarborough, Ontario
If you want to give me those frequencies, I will see how well I can receive them and possibly add them to the high altitude feed.
Cheers,
Kevin
1905z CLEAN 83 KC-135 with Gander on ATC feed to join with Tabors
flight of 6.
I think CLEAN 81 KC-10 has cleared out for home.
darrylcn
Halifax NS
I believe they did. I found some semi recent pics of the KC-135 that accompanied them before they overflew YHZ and it seems to be out of McConnell AFB, which explains the hard right they took as the F-15s carried on to KBGR.
TABOR 31 flight of 6 off today around 1230z with CLEAN 72..
Should be an hour earlier than yesterdays delayed flight.
scouseian
CLEAN72 will return to Mildenhall at 30W and CLEAN71 will drag the rest of the way over
Blackink
Central Vermont
So these airplanes that I rarely see in the skies over Central Vermont that are re-fueling, are they always Air Force planes?
Both planes seem quite large to me. I've never been near a scanner to listen to any transmissions when I did see them so I can't verify for certain.
And.....if I do see these planes over Central Vermont here in New England and they are military, is this practice or are they on a "mission"?
Thanks,
Steve
scouseian
Cheers,
Kevin
Hi Kev, I take it as you were talking about your feed on LiveATC? This feed is no longer showing as active.
Regards
Ian
looknlisten
CYQI, AR20 CP
Looks like AR20-SW will be active shortly.
SPUR74 (KC-135R, 58-0021) told Boston he will be on AR20SW.
Will orbit Sydney VOR awaiting his receiver then headed to Halifax, NS then CYQI (Yarmouth).
Clear skies in Yarmouth...hope to see something interesting.
Via comms at 2100Z
darrylcn
Halifax NS
Here's a few shots my brother and I took. He's in a better location, similar to looknlisten's. I'm south of the AR track, mine is the first image
looknlisten
CYQI, AR20 CP
First rate shots Darryl!
I had to boost my ISO up because of the low-light.
FYI...Bomber A2A was 300.125.
They switched to Boston Centre on 269.300 at 2319Z
darrylcn
Halifax NS
Thank you Howard. If I can just steal a few hundred more of my brother's photos maybe I can catch your number of epic shots ;).
He's not a forum member but I'll tell him you liked em.
looknlisten
CYQI, AR20 CP
DOOM Flight - AR20-SW
Sadly, the flight broke off just after Halifax.
This was the best I could do;
