Mid-Atlantic MilAir 2023
Larry51
Chesapeake, VA
There were some disadvantages. Back in the 1960s and 1970s, while it’s true that virtually all non-military comms were in the clear (and most of those were, too), changing freqs wasn’t easy. The scanners were all crystal-controlled. If you wanted to add a new freq, you ordered the correct crystal from the crystal company and waited for the mail to deliver it. Then you’d take the screws out of the scanner, slide the chassis out, plug in the new crystal and reassemble the case. Most scanners could hold eight crystals. If you wanted more frequencies, you bought a second scanner. And we did.
There was no searching a range of freqs, obviously. Sixteen-channel scanners showed up later and I once presided over four of them. And programmable scanners that could receive VHF air came along later. If you wanted a simpler life, you stayed on HF.
I remember back in 1973 I had a Radio Shack Pro-2 (or Pro-2B - not certain) that tuned 30-50 and 152-174 MHz with a tuning knob. It also had slots for 1 or 2 crystals. I was living in Maryland outside of DC at the time in a 6th floor apartment. One day as I was tuning up and down between 163 and 174 I picked up the USSS and WHCA for the first time. "Crown to all cars and stations: signal 5 and 9 on CHARLIE". I later found out that Crown was the White House (WHCA) alerting everyone on CHARLIE frequency that a POTUS movement was imminent. Those were the days.
POTUS travel Monday...
EDT
10:00 AM THE PRESIDENT departs the White House en route to Joint Base Andrews South Grounds
10:30 AM THE PRESIDENT departs Joint Base Andrews en route to Pueblo, Colorado
MDT
11:55 AM THE PRESIDENT arrives Pueblo Memorial Airport, Pueblo, Colorado
3:45 PM THE PRESIDENT departs Pueblo, Colorado en route to Joint Base Andrews
EDT
9:30 PM THE PRESIDENT departs Joint Base Andrews en route to the White House
9:50 PM THE PRESIDENT arrives at the White House South Grounds
morfis
CLEAN01 up on a Mildenhall - Mildenhall supporting TABOR71 Flt of five F15s (TABOR76 airspare rtb Lakenheath)
In case there are any online receivers you can use: 293.825 <494FS> and 246.050 Coronet West Primary
11 and TABOR81 Flt due
DaveC1952
Bedford
CLEAN01 KC-135 63-8888 F-15E's TABOR71 Flt 334/313/201/310/202 Air Spare RTB 312 TABOR 76
CLEAN11 KC-135 63-8874 F-15E's TABOR81 Flt 96-0204 81, 91-0604 82, 0602 83, 00-3001 84 and 91-0312 85 Air Spare for both Flts
Tank67
New York
Lot of 4 digit C-17 types lately going overseas out of Andrews.
News report says possible Potus visit coming up.
Prob one of those late night sneak visits.
RCH3235 up out of Amman, Jordan.
Probably an arms shipment, RCH799 popped up near Dimona, aka probably coming form Nevatim
EDT
MDT
EDT
From a WH official:
"The President’s trip to Colorado is postponed and it will be rescheduled. The President will remain at the White House to participate in national security meetings."
mdmonitor
From a WH official:
Makes one (me) wonder if the original Pueblo sked was a ruse. Sked a trip, then postpone it so that POTUS can look "presidential" by staying behind.
