Mid-Atlantic MilAir 2023
dmi
Somewhere In, MD
VP travel MARCH 16, 2023
At 9:20 AM ET, the Vice President and Second Gentleman will depart Joint Base Andrews en route to Des Moines International Airport.
At 11:05 AM CT, the Vice President and Second Gentleman will arrive at Des Moines International Airport.
At 3:40 PM CT, the Vice President and Second Gentleman will depart Des Moines International Airport en route to Joint Base Andrews.
At 7:00 PM ET, the Vice President and Second Gentleman will arrive at Joint Base Andrews.
Tank67
New York
mdmonitor
VIP Movement Summary (does not include POTUS, VPOTUS, FLOTUS travel)
DATE: 15 Mar
SAM 000 (C-37 # 99-0404) ADW-Nashville-Knoxville-ADW
SAM 334 (C-37 # 97-0400) ADW-Tinker AFB OK
SAM 2A (C-37 # 99-0402) ADW-NYC
Marine 101 (C-37 # 166377) ADW-Camp Lejuene NC
SAM 439 (C-37 # 06-0500) ADW-MacDill
SAM 489 (C-37 # 18-1947) Scott AFB IL-ADW-Scott AFB
mdmonitor
1330- Pioneer 77 (P-8 # 167956 VX-1) working Bay Watch (305.2) advising no joy on Quantico arrival so requests QSY to Giantkiller. Working GK (118.125) for entry into Atlantic test Track at FL220.
1350- Deed 205 (C-17 # -7-7178 3rd AS DOV) off Quantico.
1352- Acft "800" calling Base on DHS discrete (136.275)
So not only do we not escort our reconnaissance aircraft we have no ships operating in the Black Sea either
Ex Def Secretary Esper said today he would order CAP patrols along with the drones..
Publish a notam for that airspace and away you go.. F-22's hanging in the area will stop that silly pilot stuff.
Couple weeks ago the RAF sent their OC-135 up to Murmansk area but also had along two Typhoons..
That alone stops any adversarial hotdog pilots from trying any tricks..
Tank67
New York
Someone just said on 282.3 “FL 250” but I don’t see anyone on adsb and only got the tail end of the transmission unfortunately
Picked it up again with 5 bars of reception 8 minutes later "decimal 7, thanks"
Two Russian Su-27 aircraft conducted an unsafe and unprofessional intercept with a U.S. Air Force intelligence, surveillance, and reconnaissance unmanned MQ-9 aircraft operating within international airspace over the Black Sea on March 14, 2023. Russian Su-27s dumped fuel upon and struck the propeller of the MQ-9, causing U.S. forces to have to bring the MQ-9 down in international waters.
Tech792
Central NJ
Most likely fighters passing through. They usually don't show on ADSB.
2115 local someone on 340.250 chasing someone sounded like BRAVE-01.
Also same up on ZDC Brooke 285.450 says about 30 miles South of DC.
2120 BRAVE trying to contact Huntress and cleared back to Andrews on 340.250.
2121 BRAVE-01,02 on ZDC Sea Isle 281.450 talking about TOI near DC National.
NORAD exercise?
Coms on 281.400 about Guard Dog and may go hold at Nottingham.
2140 Weak coms on Andrews appch 348.725 so guess horses back to the barn at Andrews.
Hbright
NORAD exercise?
You might want to check your clock.
