Minitor 5
BlueDevil
WA
Our fire department uses Minitor 5 pagers.
I am curious if anyone knows how to program the pager so that it does not have that loud squelch at the end of every transmission. Or is this even possible? It would be nice if you could program PL tones into the pagers to help solve this issue.
Thanks!
KAA951
Kansas
Thanks!
They definitely can- my M-V doesn't squelch after a page is received, and it doesn't have a PL tone installed.
Need to talk with your programming folks.
W2GLD
Southeast Michigan
It's in the revert setting, I believe I set ours to revert n but I'd have to verify that in a codeplug tomorrow...
BlueDevil
WA
I do the programming but am not an expert on it by any means. Our pagers are programmed to revert.
CommJunkie
FN20jf
That loud squelch is the recorder basically holding the reset button so it doesn't miss any traffic within the specified time. It records in 8 second blocks, so you will have to play with the settings depending on how your dispatch center works to figure out a reset time that doesn't cut off recordings. You can also manually hit the reset button and it will stop the noise.
W2GLD
Southeast Michigan
Thanks!
Here's what I set them to for our agencies; these settings are under the "Model Options" tab in the PPS software.
Stored Voice Function: Dynamic
Reset Function: Delayed N (9.6 Sec)
Squelch Level: 3
***Note*** By using the "Delayed N" option, the pager will activate upon receiving the tones, monitor/record the dispatch and then after the 9.6 second timeout, it will revert back to standby mode.
I think you should try the various options under the "Stored Voice Function" & "Reset Function" and see what works best for your agency. Those are the two options which control the open squelch upon dispatch.
Good luck and let us know what works for you!
Regards,
Jerry
BlueDevil
WA
Thanks for all the replies.
To be a little more specific I am interested in getting the short squelch that takes place after every transmission while in the monitor mode. For example most radios will continue to hold the carrier tone after it stops receiving a signal to prevent the squelch that I am experiencing on my pager. It may be a setting that needs to be adjusted within our repeater system, bit the pager itself.
Any ideas?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Any ideas?
Eliminating the normal squelch tail requires circuitry that the Minitor does not have and is unlikely to acquire. You just gotta learn to live with it. There's a whole generation or two of us that grew up and worked our entire careers with two-way radio systems that didn't block the squelch tail. It's music to our ears....
