Minitor V erratic powering off and on
methusaleh
New England
I was issued a Minitor V, the first pager I've had, thanks to a department grant. 'I've had this pager for about two months. I received it when it was brand new, straight from the dealer after programming. I have never abused it in any way, shape, or form. When I am on a call I take my issued HT1250, so the pager doesn't get damaged. Two days ago, it suddenly began powering off and on by itself. I tried removing and re-inserting the battery. Tried wiggling the battery ever so slightly (as much as it allows with the battery locking tab in place). No matter what I do, the pager completely erratically turns itself on and off. Even if I am not touching it and it is sitting on a desk, it suddenly will power down or cycle between powering off and on. I am fairly knowledgeable about electronics and figure if the problem is small I could fix it myself rather than waiting for a long turnaround from the shop. I have not opened the pager or attempted to fix it beyond troubleshooting.
Any ideas?
Mr_Observer
"'I've had this pager for about two months. I received it when it was brand new,"
If its only 2 months old. Its still under warranty. Send it back to Motorola and get a replacement. If you attempt any repair it will certainly void the warranty.
krokus
Southeastern Michigan
I agree with the warranty repair suggestion.
If you decide to repair it yourself, check the normal intermittent contact suspects. I recently had to have the case replaced on a Mintor V for the same problem. (I'm not quite sure what was wrong with the case, but that was the statement from the repair facility, and the part we were charged for.)
brian209
South Windsor, CT
I've seen problems with the Min V where the battery lock not being slid out to secure the battery will cause similar behavior. The only thing that you say that makes me think this is not the case is that it will power cycle when sitting on the desk.
One of my least favorite things is trouble shooting Minitor V pagers. Sometimes they seem to have a mind of his own.
Brian
Tech792
Central NJ
This is one of the many common problems with the M5. Send it in to the depot and they will swap it.
methusaleh
New England
Thanks folks, I will keep you all updated on the outcome.
Good point about the warranty, I forgot all about that. I was contemplating looking at it myself only because of the delays we've had in the past when returning radios to the shop for service. Then again those were long their beyond warranty periods.
