TRX-2: Mobile installation
N6PIV
Pleasanton, CA
I purchased a TRX-2 specifically for the remote control head feature to install it in my daily driver but in testing it became clear that you run the risk of corrupting the SD card if you just drop the power when you turn the car off. For those of you that have installed the TRX-2 in your vehicle, how stable is the unit? Have you seen any issues with the input voltage drop or noise when starting the vehicle with the unit on?
I have thought about something like Mountain West's 12V UPS but it seams crazy do need to add this. West Mountain Radio - Super PWRgate PG40S
Hopefully Whistler will update the software at some point to fix this issue.
Any real world experience or suggestions would be appreciated.
Thanks,
Art
WhistlerWendy
Northwest Arkansas
Hi Art -
This issue has been fixed for the WS1095, WS 1098 and TRX-2 with the latest update. A delay was inserted during the power down phase as to not corrupt the SD card.
Please be sure that you have installed the latest updates through the PC app.
Thanks,
WW
W3DMV
Gettysburg, Pa
I had the same problem with several radio,s and since I make
Many short trips, it becomes a pain.
What I did - I have a high speed recording volt meter and
Connected it to the power at the scanner. The voltage drop was
Amazing and I would see reading less than 9 volts while the
Engine was cranking.
The power cord supplied with the scanner is way to light. Looks
Like nr 28. Made my own power cord using no. 14 copper stranded
Wire and things in proved dramatically.
Many vehicle batteries you buy from the mass retail and wholesale
are no where as good as their advertisements. Several ones I
used had very poor voltage when cranking, and often fall below
the sense voltage setting of the scanner.
Got mad and purchased to good Interstate battery for a few
bucks more. Measurements now showed the voltage never
dropped below 11.75 volts when cranking.
Since making these changes several months ago, have had
no problem with the scanner re-booting with about 20 starts/day.
Also pay attention to your fuse holders. The plating and contacts
are very poor and a little dirt and crud can cause you problems.
That's how I fixed the problem in my car. Good luck...
N6PIV
Pleasanton, CA
Hi Art -
Thanks,
WW
Wendy: I updated the firmware and so far I have not had the any corruption issues other than that I had to reformat the SD card. It does take 55 seconds to boot after power on unlike any other radio I have. Are there any plans to improve this?
Thanks,
Art
N6PIV
Pleasanton, CA
I just tried an 8 gig card and the boot time is now 45 seconds, better but still not great. I next tried an old 256meg card an I am now down to 30 seconds. At this point I am going to install it with a larger power cable and see what happens. Thank you for everyone's help.
Art
03msc
RF is RF
The Natural State
Just a quick question how many playlist do you have turned on and how large are your playlist as I am not seeing that long of boot times on my TRX-1 and TRX-2.
Do you have the latest firmware on both? Mine loaded much faster until a couple or so updates ago (Wendy has posted the reason why it's now longer).
N6PIV
Pleasanton, CA
I have the latest software and I have just one scan list currently active that includes one trunked site. I do have a number of other systems programmed but they are locked out. A good test will be to delete the locked out systems and see if there is an improvement.
Art
03msc
RF is RF
The Natural State
According to her post, and others, the "verifying" step, which takes so long, is looking at the entire card and is basically checking to see what is blank/available. My understanding is that it is not related to how many systems, etc., you have programmed.
N6PIV
Pleasanton, CA
Thanks,
I am sure Wendy and team will address this at some point. It is really nice having the manufacturer participate in these forums.
Art
