Monroe County?
rdale
Lansing, MI
"oh and by the way....just so Rob knows..........there are 3 towers that were built.......not 2."
That's correct... The original plan had Dundee + 2 new, earlier this year they decided to go with 3.
"Dont believe me?"
The frequency listing shows 4 towers, so regardless of believing you or not I think the FCC would be considered accurate.
KB8UYC
Ypsilanti Michigan
So now I cannot have pictures either? are you going to report me too rob? I did not think so.........
rdale
Lansing, MI
"So now I cannot have pictures either? are you going to report me too rob? I did not think so........."
Take your personal issues elsewhere.
AAFD
towers
does monroe county intend to still use the tower in ida i thought i read some time back they were going to put one in whiteford township.
thanks
rdale
Lansing, MI
As the link above from the FCC shows- Newport, Monroe, Ottawa Lake and Dundee.
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
The Ida tower will used for fire paging on 154.430, and 453.625 MHz., which is the county EMD frequency. The other UHF frequencies will be phased out over time, with the exception of 460.425 MHz., which is used for the law enforcement MDCs. However, that too will be replaced in due time with a new system.
73's
Ron
Thunderbolt
Ann Arbor, Michigan
Here are the MPSCS, Monroe County frequencies:
01 866.0500
02 866.3000
03 866.3875
04 866.8000
05 867.4000
06 867.9000
07 868.4000 Alternate Data Channel
08 868.9000 Primary Data Channel
73's
Ron
AAFD
monroe county
thanks for listing the tower sites rob and the freqs. ron im putting them in the scanner now.
thanks again
aafd
gwessel
Dundee Mi.
Monroe County System
Tonight at 10:30PM they are going to try to put some of the towers online and do testing. The system is expected to be ready within a month.
KB8UYC
Ypsilanti Michigan
AAFD,
Just in case you did not know, as of right now as stated above the CC is 868.9000 which is the CURRENT Dundee tower site, we dont expect any changes in that for the other towers since it is a Simulcast system. And if you did know that....then disregard my statement!
And yes, over the next month a lot is going to be happening with Monroe County, all I can say is be monitoring it, I am going to be using Pro96Com on it...
Hope that helps....
Eric
KD8FSJ
Ann Arbor, MI
Re: Monroe County System
Nice tip! The techs are on TG 1039 at the moment. New tower is T0218.
Paul
KB8UYC
Ypsilanti Michigan
Hey paul, are you going to be leaving 96com on while you are at work also????
and Paul, dont forget to read the tid bit I put on the other board reference Monroe County!!
Eric
rdale
Lansing, MI
Tower ID
The latest update says Monroe Co towers are #224, not #208 - whazzup?
WTFD10
Where the Buckeyes meet the Wolverines
Noob Question
Pardon my ignorance but:
Shouldn't I be able to at least hear bursts of static and see talkgroup IDs on my Pro-92?
Or does this system work differently than an analog Motorola trunked system?
Just trying to get some IDs for when and if I get a Pro 96 :)
KB8UYC
Ypsilanti Michigan
With a Pro-92, you will not be able to hear anything except buzzing on the control channel, and when someone keys up, you will not be able to hear any voice, just a bunch of buzzing.
and at the same time, that means that you will not be able to get any ID's....
Hope that helps you out!
Get a Pro-96.....you will not be dissappointed!!
Eric
rdale
Lansing, MI
How does the audio sound? All other CQPSK systems across the country say the audio sucks, drops out a lot and has tracking issues - anything like that happening?
- Rob
rdale
Lansing, MI
Dundee
Dundee now is listed with a separate tower number and only a two-freq tower... Any idea why that would be the case? I thought a simulcast system meant all towers were the same?
- Rob
KB8UYC
Ypsilanti Michigan
Rob
Watch and wait.........there will be more changes in the next couple of weeks, remember most of us have never seen a "True Simulcast System" in action, and because you are asking.....I dont think you have either....
everyone is watching this system.....so just watch
