SDS100/SDS200: More Volume
JobabeBob1981
Cornwall NY
I am utilizing my SDS100 in my vehicle need more volume?
Is there a way that the scanner communications can go through the radio of a 2018 Toyota Rav 4?
nessnet
Eastside of Lake WA
I have no idea if your Toyota radio has an aux input.
I have a Subaru head unit with an aux input and it works just dandy foir this.
If the Toyota unit does, just plug the scanner into that.
Trav6028
East Hartford CT
Aux input in radio? Set up a blue tooth output from the SDS100 that the radio will pick up like a phone does?
tvengr
Well Known Member
Baltimore County, MD
If your AM/FM radio has an aux input, connect a stereo 1/8" mini plug cable between the scanner and the radio. If you are running the radio on external power, I would use an isolator between the scanner and radio.
JobabeBob1981
Cornwall NY
Will check it out
TY
