Morris County TRS...
RocketNJ
Pequannock, NJ
no berchwood area by the mall
If you are near the mall area near exit 35 on Rt 80 then you should only program in the frequencies for Zone 1 in the database.
Do not program the frequencies for the other 3 zones, unless you are travelling to those areas. If so then set up new systems for each zone. This way, the scanner will only lock on the frequencies nearest you. Otherwise you could be locking onto frequencies that are further away causing your reception issues.
FYI - Dover
I am now hearing Dover (49 Cars) on the system on MUN PD 2.
I Added a submission to the DB already.
SCHS4180
Dover came over as of 1030 this morning. PD on MUN-PD2, fire/ems on FIRE RESP 2 AND DISP-EMS2.
RocketNJ
Pequannock, NJ
They'll probably shuffle around some talkgroups. On or about 8/1. Date is not firm. May happen last week of August.
