Moto Astro Spectra Programming Help
NF2F
Mt. Dora Florida
I have a unique issue. I have programmed numerous ASTRO Spectra 40 watt trunk mount mobiles. When I plug them into our ARES communicatins trailer, I get an error of FL01/.90.sometimes....then the radio powers up and goes through the self check and receives fine, however even though the PTT light comes on when I depress the mic, I get neither exciter or PA transmit.
I measure 13.8 volts at the radio and have programmed other of the same radios with no issues. Anyone ever experience this? Thanks.
radioman2001
New York North Carolina and all points in between
That error can be more than just no power, it could be a bad control cable or bad head. FL10/90 is loss of communications, or even the MLM came loose in the radio. I would go back to a working setup and confirm the radio and then replace one by one each item in the trailer to see what failed.
