Motorola Astro Saber VHF Test Freq
TheWarlock
Mississauga Ontario
TX 136.025
RX 136.075
Hope that helps.
Thanks for that. I tried to transmit however I didn't hear anything on the Pro-91 scanner I have. I even tried scanning the VHF band and got nothing when trying to transmit. I don't even see the red light turn on. When I have the radio in normal mode and press PTT i hear a low tone. What could cause it to make that tone when pressed but nothing is heard at all when I try the 1CSQ channel.
I use this radio as a Scanner but I was thinking of programming a channel to talk/receive on Ham when I get my licence
Arizona
The low tone is because the radio is set to only receive on that channel. That is done in the CPS to program the radio. The red light won't turn on with the PTT because the radio knows it is not supposed to transmit on that channel.
TheWarlock
Mississauga Ontario
However If it is trying to transmit on the test channel is service mode is should transmit right?
Pro-91, MTS 2000 800MHz, Astro Saber VHF
TheWarlock
Mississauga Ontario
What I am saying is the PTT button is recognized by the radio when it is pressed. But in service I get no TX at all when I press the PTT button.
rescue161
KE4FHH
Hubert, NC
You use a service cable and connect the radio to a service monitor. Then read the radio with Astro Tuner. Once in Astro Tuner, you can transmit using the the software. It will give you the frequencies and allow you to adjust certain things like frequency error correction, receiver sensitivity, etc.
