MOTOROLA CPS Help
tkaplan501
Croton-On-Hudson, NY
Hello all,
So I have the version on Moto CPS for the HT1250/750. It also works for my EX600 XLS. I just spent 4 hours entering all the frequencies into the conventional personality (channel information) for my 1250. I want to use the same conventional personality for my EX600 XLS, but I can't program both radios on the same file, because the radios have some different settings. Is there a way I can copy or transfer my conventional personality in my 1250 file to my EX600 XLS file? PLEASE HELP!!!!!!!
Open another instance of the CPS so you have the 1250 code plug open in one window and the EX600 code plug open in the other.
You should be able to drag and drop from the 1250 code plug into the EX600 code plug.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Neither Drag and Drop nor Cut and Paste works on the Pro Series software. It is a well known and major weakness of this package.
Sorry to be the one to tell you, but there is no Drag and Drop or Cut and Paste in this software.
Also, the only way you can use one codeplug on multiple radios is if they are EXACTLY the same model numbers.
If you would poke around a bit here and read back through any thread that involves the Professional Series radios, you will find lots of information about programming them. Your question has been answered before.
I stand corrected, or enlightened... whichever. I've never worked with the Pro Series CPS - just sort of guessed it was possible. Yay Motorola... :confused:
