Motorola DM/XPR RX Issue
EI2GLB
Hi All
I am just after getting a DM3600/XPR4550 and I have a issue. I am using it for DMR on a simplex gateway, If I just monitor 2 stations talking it works perfect, If I join in the conversation when I unkey I miss the first 2 or 3 seconds of the next guys transmission, everyone is supposed to leave a gap in the system and they do appear to but for some reason my radio seems to be taking a long time to go back to receive, I can see the person transmit on the gateway dashboard and I can see the signal on the radio, but it just takes a couple of seconds for the audio to pass, I have searched in Google and all over the codeplug but can't see a setting that fixes this, My Anytone HT does not have this issue,
As an example, on BM if I key TG4000 to unlink a TG when I get the automated reply I only hear the "ED" at the end I miss the "UNLINK" part,
Trevor
It's actually "NOT LINKED" that is transmitted Sorry
Anyone any idea ???
Did I do something wrong here, why is no one answering me???
Surely someone has an idea what could be wrong??
K2NEC
5F6
We(RR users) don't have an idea. If someone knew, they would answer. We aren't geniuses and sometimes problems are so unique that we don't have a clue.
EI2GLB
Thanks for the reply good to see I am getting out as the say,
I think it's a Pi-Star <-> Motorola issue it's not the end of the world I'm more of a SWL than a rag chewer anyway,
Thanks again and stay safe,
73
Trevor
EI2GLB
Tech21
The call hang time is probably set to high. Change it to 2 seconds or less.
EI2GLB
Hi
Thanks for the reply, I am unsure of that setting is it this one,
84204
Tech21
Under general settings, you should see a setting called "call hang time" = it's generally set for 3 seconds standard. It could also be the subscriber on the other end has their radio set to keep the channel busy just a little too long.
