Motorola GM300 Programming - Radio not detected
vu3fxe
Hi All, I got an old Motorola GM300 recently and since some of the local repeaters were already programmed in that, I never cared to reprogram. Now I've moved to a new location and when I tried to reprogram the device, the radio is not getting detected in the software. I understood that it was modified from 16 channels to 30 channels when it was given to me and on checking with many friends, they are giving me a note that it cannot be reprogrammed again. Any options are there to factory reset it or revert to the original 16-channel mode for programming it via the original software? Regards, Harry
vu3fxe
Alot ot unpack here. Are you using a DOS PC ? RIB ? Programming Cable ?
These are old radios but with the proper stuff they can still be programmed. We need much more detail than given to help.
I am using a Win 7 PC with an FTDI programming cable.
marcotor
I ♥ÆS Ø
Sunny SoCal
DOS doesn't do USB of any sort. If your "FTDI cable" is plugged in to a USB port, you found your problem. You do NOT need a RIB, but you do need the proper OS (DOS not Win7) and "ribless" serial programming cable.
I never did understand the "old and slow" comments, I can program a GM300 all day on my i5 and i7 Toughbooks booted into DOS from a flash drive.
buddrousa
I had in the shop 3 Toshiba 75MHZ Laptops would not work with out SLOMO running. Factory Software Factory Rib Box and Factory Cable all in a Motorola Shop. The SLOMO was a Recommendation from Motorola.
vu3fxe
I
vu3fxe
I tried to connect gm300 via FTDI cable to Radio Doctor software for programming. The FTDI is getting detected as a USB serial device in the device manager in win7
vu3fxe
Quick Update - I've managed to sell that device to another HAM who is staying near my old place and who only need to access the repeaters which are already programmed in it.
