Motorola Minitor 3 Engineering Data
jerry092975
Chester County, Pennsylvania
I have a Question: in the programming win PPS Software for the minitor 3 and 4 pagers is it possible to change the frequency range ? (example) freq range is> 151.995 to 158.995 mhZ is it ok to change it to 159.000 to 166.9999 mhZ With the Engineering Data login screen you can change the pagers frequency range. BUT i don't know if the crystals installed in the pager will allow the change.
kb3isq
Shippensburg, PA
You can change the frequency but you will lose sensitivity the further away from original frequency range. I changed a 151-158 minitor 3 and 4 to 159-045 and 159.075 with no problems. Try it you can't hurt anything and if it doesn't work you can always change it back.
