Motorola XTS 1500 help
codymw623
Ebensburg PA
Hey i have a general question about the Motorola XTS 1500. I am using this model of radio for conventional channels and for p25 channels. This may sound stupid, but is this radio only good for one or the other. I was looking under the Conventional Personality and under the tab TX options. There is only 2 options listed (astro voice and Non-Astro Voice.) My question is when i set the radio to Astro voice i am unable to transmit on the Conventional Frequencies because it puts the voice into the digital format, but am able to transmit on the p25 frequencies with out a problem. When i switch it to Non-astro voice it will transmit on the Conventional frequencies and not the p25. Is there a way to transmit on both with out having the problem. I have seen other users do this.
Cody
RodStrong
West
You need to add another conventional personality, so you will have one for digital, and one for analog. Then you will need to assign whatever channel/frequency you want to the appropriate personality.
Good luck.
