Motorola XTS 3000 Error 01/02
Cashanova48
GMRS callsign WSAF780
Hello all,
I own a XTS 3000 III:
model: H09RDH9PW7BN
Flashcode: 540001-000000-4
System Package: H35
Firmware: 07.71.00.00
DSP Software: N08.03.03
The radio has performed very well, except for recently randomly restarting.
The radio will RX fine and won't restart, unless you: change zones, channels, or scroll through menus.
Sometimes, the radio will display "Error 01/02" on the screen after restart. From my research (Not a lot online for this topic), it seemed like this is a type of Coad plug checksum. However, I have no flags when viewing the code plug. I saw another forum (Xts3000 randomly restarts) where it was stated that an Impress battery can cause some of these issues. So, I taped over the middle contact and bought a new aftermarket non-impress battery. I feel like it might restart less, but it still does it fairly often. I was wondering if anyone else had run into any issues like this before?
Also: while in the ASTRO Saber & XTS 3000 CPS, I noticed the section "Singletone", under "Conventional", while in the "Feature" tab. I know the XTS 3000 is not able to do QuickCall, but is it able to do Singletone, or is this a feature of a different radio that uses this same CPS?
Thanks for reading this post, I greatly appreciate any reply's.
*Edit*
At times, the radio will sit on a channel, and constantly restart, without pressing any buttons. Making it completely un-useable.
Cashanova48
Also: I've thought about writing a new flashcode, which would hopefully solve this (If it was an issue with programing) and adding a few features. My only concern is, if the radio tried to reset while being flashed.
nokones
Sun City West, AZ
Hello all,
model: H09RDH9PW7BN
System Package: H35
*Edit*
Did you try reprogramming the radio again?
Singletone also known as Burst Tone more than likely is no longer used on an analog conventional system. It was widely used to unlock specific receivers at remote or base stations by mobile and portable units and sometimes point-to-point by dispatch centers. The singletone would be transmitted everything the radio is keyed for a one second Burst duration. The common tone frequencies were, 1800 Hz, 2000 Hz, 2200 Hz, 2400 Hz, and 2552 Hz.
The use of a Singletone on a system may be used in conjunction with a PL tone.
firefive76
Kansas
Singletone is not the same as guard tones, function tones, key tones, etc., which are used to remotely control receivers, voters, repeaters, or radios.
nokones
Sun City West, AZ
Are you saying that the info in my post is "Bunk" and I cannot program any of my XTS portables to perform as I described in my posting to unlock a remote or base station receiver with the five tone freqs I have listed like they did back in the 60s or 70s?
If you're saying that can't happen than, what is the "Singletone" feature's function in the XTS series radios and why can I program that feature in my XTS series radios and when I key it emits the respective tone in a one second duration every time I key the radio? Just curious if I am wrong and kinda "bunked up!
KevinC
32D2T/957.282
I'm everywhere Focker!
How are you "writing a new flashcode"?
Cashanova48
How would I go about a new codeplug? Would deleting everything minus a personality, then starting over do it?
KevinC
32D2T/957.282
I thought Depot was completely separate, but I suppose that's it.
I refer you to this post...
And an addendum to the prohibitions in the original post…
Discussion of ways to hack or bypass licensing for legitimate software will be shut down and deleted immediately, as will discussion of ways to acquire restricted software, or possession/use of restricted software such as Depot. Likewise, discussion of ways to bypass system key protections, illegally obtain system keys, or illegally create system keys will be deleted immediately.
