Motorola XTS3000 CPS
tgrahmann
Hi, I'm sure this has been asked before but I haven't had any luck finding an answer. Does anybody know where one would find the XTS3000 Astro 25 CPS? I've found an older version but when I try to "Read Device" from within the software I get a "Failed to Read Device" error. I researched that and it said I needed a newer version (which I was unable to find anywhere). if anybody has any insight on this that would be great!
Tech792
Central NJ
XTS3000 doesn't use Astro 25 CPS. It uses the 20 year old Astro Saber CPS. I don't have the part number in front of me though.
Sent from my LG-D321 using Tapatalk
tgrahmann
The Astro Saber 25 XTS3000 Software is actually what I had found, sorry for misnaming it. However, I have a version that is not "up to date" and It won't read my radio.
tgrahmann
Let me also follow up with the fact that I AM running this version (5.03.00) of the Astro Saber CPS on a Windows Virtual Machine with a RIB-less cable AND a Serial to USB adapter. Could any of that cause this issue?
tgrahmann
I'm Running XP Pro in Parallels with a USB-to-Serial cable attached to a RIBless cable. I don't feel like any of that would affect this issue, but could it?
tgrahmann
I'm using a RIBless radio-to-serial cable from Valley Enterprises. Checked the ports and they're correct. Do you think its the 5.03.00 version I'm using?
I suppose its possible you using latest firmware on that radio witch actually the last one i think was firmware 7.71.07 dsp N08.03.05
Anderegg
Enter text in this field
San Diego
tg, I similarly run XTS3000 CPS from Parellels 12 on a Mac. My older Cables2Go USB serial adaptor stopped working some time ago (6-8 months), due to a change in an update to Parallels, simply did not work, got the same error as you did. I replaced my blue C2G USB to serial adaptors with one from IOgear, and everything is working fine now. Old blue has been replaced by new grey.
About $13 from B&H photo video https://www.iogear.com/product/GUC232A/
Also, does XTS3000 CPS read/write on 64bit Windows 7? I was under the impression it only works properly under 32bit, but maybe that is for serial port RIB use?
Paul
