Mototrbo CPS2.0 incompatible codeplug version
emanuel32804
Hi all,
I have an XPR 7580 that I'm trying to read the plug from. I currently have CPS 2.0 2.122.70.0. It's the newest version available to me. The radio's info section reads CP Version 21.10.07. However when I try to read it, I get an error that the firmware versions are not compatible. I figured using the newest possible CPS would guarantee a good read. Do I need to use the newest version of the old CPS? I have CPS 16.0 build 828 available to me as well but I haven't installed it. Also available is CPS 2.134.76.0. Anybody got any idea? So confusing now that its splintered like this.
Thanks,
Emanuel
emanuel32804
Alright I'll give that a shot. Thanks
Out of curiosity, why doesn't CPS 2.0 work if I have the newest version of that? Does the radio need a newer firmware?
Firebuff880
Boynton Beach, FL
An what does this section tell you the Firmware Version is -- What CPS you use is somewhat dependent on what Firmware you have, not the CP Version. An XPR-7580 is an older model of the subscriber. The current version is an XPR-7580e.
emanuel32804
I believe (don't have the radio in front of me) the FW is R02.21.01.0000. That may be a different version number, the only picture I took has the title of this number cut off unfortunately.
emanuel32804
Just in case anyone was wondering, using the newest CPS (2.134.76.0) I was able to read successfully! Thanks for the help!
