MotoTrbo PL Issue Codeplug Issue
zakharabedian
Flemington NJ
All, I am having an issue with two of my mototrbo radios in analog mode. They both have PL tones in them but while scanning it interrupts the scan and shows MDC identifiers popping on the screen from a different county that is on the same frequency. I'm not sure what is causing it to do this considering they both have the correct PL tones put in them and in the scan menu it is set to prority and non priority channel requires PL. Please give me some possible solutions or area to check in the codeplug. Thanks!
Avery93
AL
Don't have TRBO CPS in front of me, but check under the receive section of your conventional personalities for an option similar to "TPL/DPL Required For Data". Enabling this should prevent any signalling data from being decoded prior to successful PL decode.
Project25_MASTR
TX-COMU
Texas
Not an option in the RX section of a conventional channel (at least I don't see it).
Do you need signalling on the channel in your scan list? If not disabling signalling (according to the help window for the option) should remove receiving of MDC from the channel.
firefive76
Kansas
Yes, it is there. Make sure you are in expert view, go to the RX side of your channel clear down at the bottom. There is a checkbox that says "PL for Data." Check this box and it will fix the problem you are having (I had the same issue.)
KX4KDH
Powells Point, NC
Just for giggles, I looked at my CPS, and there is a check box at the bottom of the RX side for "PL for data". However, it is greyed out, and I can't check, or uncheck it.... I'll have to dig further into this...
KG4INW
Midlothian, VA
If you enable MDC for RX signalling, then that check box becomes available.
