MRC Systems
mciupa
Canadian DB Admin
Moderator
I'm here a lot
It has been brought to my attention that the Fire agencies listed below are no longer active on MRC Systems
Wellington County Fire​
DECModeAlpha TagDescriptionTag
13001TPFR TAC 1Puslinch Fire and Rescue - TAC 1Fire Dispatch
14001TGE- RV FD TAC 1Guelph Eramosa - Rockwood Volunteer Fire Department - TAC 1Fire Dispatch
14002TGE- RV FD TAC 2Guelph/Eramosa - Rockwood Volunteer Fire Department - TAC 2Fire-Tac
15001TCW VFR TAC 1Centre Wellington Volunteer Fire Rescue - TAC 1Fire Dispatch
15002TCW VFR TAC 2Centre Wellington Volunteer Fire Rescue - TAC 2Fire-Tac
16001TEFES TAC 1Erin Fire and Emergency Services - TAC 1Fire Dispatch
16002TEFES TAC 2Erin Fire and Emergency Services - TAC 2Fire-Tac
17001TMF/R TAC 1Mapleton Fire and Rescue - TAC 1Fire Dispatch
17002TMF/R TAC 2Mapleton Fire and Rescue - TAC 2Fire-Tac
18001TMVFD TAC 1Minto Volunteer Fire Department - TAC 1Fire Dispatch
18002TMVFD TAC 2Minto Volunteer Fire Department - TAC 2Fire-Tac
19001TWNFS TAC 1Wellington North Fire Services - TAC 1Fire Dispatch
19002TWNFS TAC 2Wellington North Fire Services - TAC 2Fire-Tac
If you are within monitoring distance, please confirm. I don't want to prematurely deprecate this entry without knowing where or what these departments are now using.
VA3ADP
Mississauga, Ontario Canada
It has been brought to my attention that the Fire Services are no longer active on MRC Systems
I was just monitoring them last week and was hearing them just fine. I'll keep my scanner on record and report back
VA3ADP
I've been hearing Roads Central Dispatch. I have about 5 hits in the last couple hours. Nothing on fire talk groups as of yet
mciupa
Canadian DB Admin
Moderator
I'm here a lot
With me only receiving Brisbane Site 10 reliably, I should be able to receive Rockwood or Erin Fire departments. Since yesterday, I have only had Central Roads, Guelph/Eramosa Works and Erin Roads. I'm also checking Prairie/FleetConnect to see if they are back there. Mostly getting IMOS on that system.
Are the FD's using Guelph's DMR CAP system now?
SiteNameFreqs
001 (1)Guelph01 412.012502 412.737503 412.887504 413.987505 413.737506 413.1125
VA3ADP
SiteNameFreqs
It's possible. Does the Guelph site have coverage into Wellington County? I also thought they might be on the TurboConnect system further south
CDTbolt10033
Waterloo Region, ON
The Wellington County fire departments are still very much active on the system. Most of the traffic is at specific sites for some reason. I have seen this where sometimes it will have FD traffic on the Wilmot site but other times (most of the time) not.
I've seen WNFS and PFR and CWFR recently according to my recordings on Trunking Recorder.
I set my site as Puslinch and most if not all the traffic is heard on that site.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Thanks for clearing this up. If I'm lucky, I should still be getting Erin FES from the Brisbane tower.
CDTbolt10033
Waterloo Region, ON
Thanks for clearing this up. If I'm lucky, I should still be getting Erin FD from the Brisbane tower.
It might be a scenario where the site allows that TG to be heard if an Erin radio is registered with that site or a nearby site. Just a thought...
gary123
As we all know on trunked systems if a mobile is not affiliated with the site, the TG is not active on it. I have seen many trunked sites where the RX "acceptable signal parameters" are deliberately tightened so that only units that are strong and solid can affiliate.
This creates the situation where units will tend to affiliate easily with the local site but have difficulty affiliating with a distant site, effectively locking out non local radios and TG and thus freeing up channel slots for local users on the site. Propagation and other factors are at play so there is no specific setting and each site would need tweaking to achieve the system goals.
