Multiple 2 tone decoding
ffemt25
Short Gap, WV
Is it possible to have multiple sets of 2 tone decoding happen on 1 talk group? I have several different stations I want my G5 to alert for off of 1 talk group but it says I can only have 1 talk group with the same TG ID assigned to any zone. Is it possible to add multiple 2 tone decodes to the same ID? Thanks in advance.
TFrank615
Springfield, Ohio
Do you know how to export your profile? If so do that and send it to my email. Easier for me to show them explain lol. Tyler-Franklin@outlook.com include what other tone pairs you want and a name for them
CFP387
Rowan County, NC
I have several tone pairs that are set to activate on a single talk group in my G5. I've found that when all the tones are set off only one pair will activate the unit. The others pass through with no activation unlike the Minitor pagers which would activate on every tone that was programmed.
Holshot14
SC Penna
I’m guessing this is over P25, cause you mentioned talk group. I have had the same issue since QC over P25 came out. I have the same 2 tone pairs on a simul analog freq and all alert! If you find a fix let me know please.
TFrank615
Springfield, Ohio
Shoot me an email with the unipps file and let me look at at, I helped this guy get his fixed up. I’m at work know but can look at it in a little while Tyler-Franklin@outlook.com
Holshot14
SC Penna
Thanks, I will, but it may be a few days til i get it to you. I’m on vacation. Thanks for your help.
hfd26
I have been having this same problemail on a Motorola vhf p25 p2 system. I've been back and fourth with unication and we still can't figure out the problem. The problem I strongly believe is the minimum tone gap in tab 3 of the programming. U can only have 500ms gap. When my county does multiple tones there's zero gap between tones. When you look at your programming for analog 2tone you see under tone 1 a zero gap and tone 2 a zero gap and all tones will activate. P25 is looking for that 500ms gap which doesn't happen with stacked tones. I've asked numerous times if tab 3 minium gap can be changed in the programming but don't seem to get any answers.
TFrank615
Springfield, Ohio
Not too sure on the VHF side with these. The other two are/were having problems with 7/800 P25
Gilligan
Hagerstown, MD
Just saw this thread and if I'm reading this correctly, I think what is being asked is if it is possible for the G5 to alert for sequential pages (more than a single one) on QCII over P25. If that is what is being asked, is that possible now? I didn't want to start a new thread if that is the same question. When I put my G5 into trunking TG-scan and have two-tone pages set up, it only alerts for the first one and then the squelch stays open for the remaining pages and dispatch.
TFrank615
Springfield, Ohio
Unless anyone else has more info, which would be awesome btw, I do not know of a way to do that yet or if it is even possible
hfd26
At this point it doesn't seem possible on some systems. My Motorola vhf p2 system it only alerts one tone. When tones are being sent out there is no gap between the tones. If there's a half Second to a 1 second delay between tones then they will alert. I be leave it's something in the programming. You can only set it to a 500ms gap
TFrank615
Springfield, Ohio
On our tones there’s at least a good 2 second gap or more between two sets of tones
hfd26
Do you have the problem with multiple sets of 2 tone activating. Mine will only set of 1 tone
