Mxt 275 repeater issue
chrs493
Big Sandy tx
I have a midland mxt 275 I am having issues with. I am trying to get it on our local 675 repeater with a 156.7 tone. I turned on the repeater function. Repeater channels appear. I go to repeater channel 20. Rt is set to 25 Ct is set to 25. I transmit and it goes through. When someone tries to respond to me I can see it receiving however no audio comes across. I have put it on monitor and it comes across fine. I have reset and programmed again with same luck. What am I missing here?
FKimble
Newnan, GA
Sounds like you have the wrong receive tone set. Just turn off the receive tone and you should be good. Or figure out the correct tone to set. How did you decide Rt and CT # 25 was the correct tone? Maybe the repeater only has a RT and does not transmit a tone?
Frank
Remove the output tone from your radio.
Don't put all your trust in the databases. It's apparent that it's likely wrong based on your experience.
chrs493
Big Sandy tx
I own the repeater so i know the tones. Sent it to midland and it was a problem with the unit.
