NCSHP Caldwell County
setuphelper
Hi.Can someone give me some advice on programming my scanner for HP in Caldwell County NC? I have programmed the 800mhz freqs & hear nothing. I have programmed for a P25 Auto system , it this correct ? thanks
setuphelper
radio shack
radio shack - handheld digital trunking - I think its Pro-106
ncdadof3
Morganton NC
Do you have the programming cable or software or are you programming by hand?
Sent from my SM-G360V using Tapatalk
ncdadof3
Morganton NC
I have a 197 I program by software and programming cable. Let me get home and I will see if I can help you any better.
setuphelper
great
thanks for the assistance - I actually do have the cable but don't have access to a good computer - I found programming by hand easier anyway - thanks
Drafin
Charleston, SC
http://forums.radioreference.com/no...n-forum/307254-pro-106-caldwell-county-2.html
The above thread, in which you replied to, has a sample file for Caldwell County in it that includes NCSHP. You could download the software and take a look at the programming to see a working Caldwell County setup that includes NCSHP.
The short answer to your question is to receive NCSHP for F Troop which covers Caldwell is that you program in the Viper Hibriten tower and add talkgroup IDs for F Troop (52187-52194 and 52229). The reason you need all the those TGIDs is that, even though 52191 is labeled as Caldwell, I don't think it's accurate and have not taken the time to figure out the naming scheme as I normally listen to all of F Troop. It's not uncommon to hear Newton calling Caldwell cars on other TGIDs.
For further information (and a known working setup) I again advise you to download the trial version of Win500 and the file in the above listed thread. It has been confirmed as working by the OP that was having a problem.
Draf
setuphelper
thank you
thank draf & dadof3 for the assistance - I will certainly take a look at the file
Drafin
Charleston, SC
No problem at all and please comeback to this thread and let us know if that helped or if you need anything further.
Draf
setuphelper
I've tried every trick I know to unzip the Caldwell file - I can't seem to make it work . any suggestions ?
setuphelper
win500
yes , I don't have access to a good computer - I have been trying Android apps that are supposed to open zip files - so far no luck
Drafin
Charleston, SC
Honestly you don't need a good computer to run a zip shell or a WIN500.
If I get a few minutes today I'll try to do a few screen grabs and post them to this thread that shows how NCSHP is programmed in that file. At the very latest I should have some time to post them over the weekend if you don't find a solution before then.
Draf
setuphelper
great
really great of you to go to the trouble , Thanks ! meanwhile I'll keep hacking away at it -
Drafin
Charleston, SC
Ok here is the basic programming for NCSHP in Caldwell on that setup from the other thread. It's VERY vanilla and nothing special but here is a visualization of it.
Draf
setuphelper
thanks
thanks draf for posting the screenshot of NCSHP frequencies & talk groups ! I really appreciate it ! - the is college move-in weekend so it might take me a couple days to plug them in the scanner & post feedback , but I certainly will - thanks again !
