need help finding a two way radio antenna
nberpa
Hi,
I don't know much about radio technology or anything, but I need to find a permanent mount antenna for a vehicle I have. I will be purchasing a Kenwood TK-730 45 watt radio and I need an antenna to be capable of receiving and broadcasting on the 151-158 mhz frequency range. The frequencies I will be using are 151.625, 151.505, and 158.400. I don't want to get a real big antenna; only something that is small and low profile, but will have a big range. The antenna can't be magnet mount because the vehicle has a fiberglass cab and roof.
Any help would be greatly appreciated!!
robertmac
As this is for commercial radio, could look or ask to have this post moved to the Commercial Antenna thread. Any Larsen antenna for VHF should be great.
mikepdx
Corbett, OR USA
You may have to scale back your requirements a bit.
You cannot get something from nothing.
Although, you may be able to use a quarter wave
if you create an artificial ground plane using mesh
or some type of foil inside the vehicle's roof.
Antenna Specialists used to have a kit with
aluminum tape as a ground plane kit
for boats, fiberglass vehicles, etc.
The concept is something to think about.
If you decide to make roll-your-own ground plane,
do not transmit until you've checked your SWR.
