Need help programming DMR into a G2 in the NH / VT area
rja1
Enfield, NH
Recently got it back from Unication after the local post office in TX "lost" it for several days. First thing I noticed was they didn't change the S/N to indicate it had the DMR upgrade. When PPS asked for the S/N, I scrolled down the list, found it & put it in. It didn't show DMR in the protocol. My S/N began with G2C66AB. I found a S/N in the list that matched perfectly except the "66" was now a "67" & DMR showed up in the protocol.
Here's the part I need help with.......I'm trying to get a Connect + system to work in the same manner that Whistler scanners use, just using voice channels. Don't think I need CC's. I'm totally confused trying to figure this out. On my SDS, I'm seeing they use slot 1 & slot 2, but the scan list only has a choice of either 1 or 2, not both. I made one protocol type DMR slot 1, & a second protocol type slot 2. Under conventional frequency setting, I put in all the sites & corresponding voice channels. Don't know what to use under receiving mode....Monitor Mode? Radio compatible mode? I tried normal scan & Under zone & channel setting, I don't see anything under Scan List > Available & Scan List> List members. After 3 hours today & 6 hrs yesterday, I need some fresh ideas.
