Need Help Programming VX-800
apsyms
Hey all,
I recently purchased 2 VX-800s (vhf and uhf), as well as a programming cable, and am looking to program each. Both radios are already programmed from the previous owner, but I am have a lot of difficulties programming it myself. I have the latest CE-31 software and the Prolific driver, but every time I plug the radio(s) in and hit 'download' on the software, I keep getting stuck at "turn the radio off, then back on". I haven't gotten any further, and have even called Vertex, but to no avail. Any help would be greatly appreciated!
Andrew
MBill
Vertex radios (depending on model) use two different methods to read from radio. Don't know if it is
the particular software or something with the computer.
Try one of these:
1. Turn radio on. Then hit upload button. When message comes on screen to turn off radio, turn it off
and then back on. Don't turn off/back on too fast.
2. Leave radio off, then hit upload button. Turn on when message appears to "turn on radio".
One of the two should work if everything else is OK.
apsyms
Try one of these:
Unfortunately, neither worked :(
willdanl
Dripping Springs, TX
Do you get any kind of indication on the radio that it is communicating with the computer at all (change in LED, message on LCD)? Have you tried to UPLOAD from the radio? You might try changing the baud rate setting in the software to see if that makes a difference. Also, you might try running the firmware installation software to see if it will communicate. Sorry if all of these were already covered in your call with Vertex.
wx5uif
Broken Arrow, OK
From what I have seen, the radios and computers are very picky with what type of usb to serial adapter is used. Most I have won't communicate with the radios.
MBill
Are you using the Vertex FIF10A or 12A programming cable? That is what is called for with these
radios. Serial cable unlikely to work.
Also in the software menus check under the "File" heading and click on "Configure". Make sure that
the FIF10A or FIF12-A is selected. You may also see some com ports listed. You could try them just
in case one works.
Could also be an issue with the software verses the computer as to what either one wants to see,
or problem with the connecting cable or driver.
apsyms
I think it might be the cable I'm using, which is one of those Chinese USB ones off eBay. I'm going to see if I can pick up an OEM cable from a friend/radio dealer. Until then I'm going to keep trying with this cable, though - thanks for all the help everyone!
T1poirier
Serial Port
Just a quick thought, you may want to check to make sure that your programming software is set to use the correct serial port (ie: Port Number) to communicate to your USB -to- Serial cable. I know if that isn't set correctly you will not be able to read or write to the radio.
You can check your device manager to check which serial port is actually the USB to Serial cable.
Hope this helps!
MBill
That could well be. Seen a number of complaints on bad Chinese after market cables bought from internet sites.
Post the solution if you find it.
