I have just programmed my BCT 15 using the registered version of the software. The problem I am having is I can only Receive the Ocean County Trunk System in the ID Search Mode. It will not receive in the ID Scan mode. I have all the Tags programmed properly, the freqs are all correct and my settings are as follows.
Status Bit - Enabled
End Code - disabled
Modulation- Auto
Attenuator- disabled
Band Plan
Base 505.0000
Step 12.5 Khz
Offset 380
Seems to me everything is okay. Any ideas ?
End Code - disabled
Modulation- Auto
Band Plan
Base 505.0000
Step 12.5 Khz
Offset 380
