Need help with programming my XTS5000 Model 1
lb2910
Washington DC
Hello from DC!!! So I was programming my used XTS5000 Model 1 recently and got most everything the way I wanted it. I'm mainly using it for MURS freqs and using the PL feature to program a few zones with the same MURS freqs but with different PL tones (RX and TX) to help with any interference problems. Well, I was going to add some of the WX freqs just to monitor with RX Only checked and when I went to my previously programmed zones, ALL the PL fields were grayed out!!! I lost all the PL tones I programmed and now I can't use the feature. I tried deleting both zones and conv personalities and starting fresh... nope.. nada... still all grayed out. I admit I'm new to all this but I don't think I did anything that would cause this. Has anyone had this issue or can help me resolve? Thanks for any help with this!!!
XTS5000 Mod1 Info:
Mod#: H18KEC9PW5AN
Flashcode: 100088-001E86-3
System Package: H38
CPS Ver. R20.01.00
Giddyuptd
Here and there
Is the conventional personalities set to analog or mixed mode. And under the xmit tab set for analog?
lb2910
Washington DC
Both were set to ASTRO.. which I was told is the digital mode... I just set it to Mixed mode and it opened up the PL tones for me to use... I assumed (which is probably half the problem given my newbie status) if set to ASTRO that the PL tones would be available since PL is digital.. So confused.. HAHA.. so what is the difference between mixed and ASTRO? Should I leave it on mixed?? Thanks William for help!!!
lb2910
Washington DC
Thanks for the clarification Jaspence!!! The DPL and PL makes sense the way you explained it. Well done...
Regarding the XTS5000 on MURS.. Even if i have the transmit power set to low?? I know I can't transmit on 5W, but on the low power setting, the specs I read were that its at/under the 2W max power for MURS. Definitely would like to know if that is not correct...
I can't thank you all enough for helping me wade through the waters of radio usage.. Def gets confusing!!!
Giddyuptd
Here and there
Astro is p25 digital. Setting a radio to astro means only digital will receive or transmit.
Mixed mode will let analog and digital recieve and depending on the transmit settings you have, will transmit in astro or analog and still recieve both in mixed mode.
NAC is a digital tone for astro aka p25.
Dpl/pl is used for analog tone squelch.
jaspence
Michigan
I bought 5 of these for our family vacation in Colorado. For the price, they worked very well, and spare batteries cost way less that a Motorola or 3rd party Moto battery.
lb2910
Washington DC
Thanks for the info Jaspence..... UGH.. so now I have two boat anchors for radios with all the restrictions... what radios did you buy for Colorado???
lb2910
Washington DC
HAHA.. one man's junk is another man's treasure?? And yes.. XTS5000 aren't technically boat anchors... but based on what I can and can't do with them, they are almost useless. I got them fairly cheap off Ebay thinking I can use them for outdoors, etc... The CPS software came bundled with one of them so I was excited that I can set them up how I want. I guess I can look into getting my own FCC frequency but I hear that can cost hundreds of dollars and take months and months to get...
Outerdog
T¹ ÆS Ø
Alternatively, you can pull a MURS license fairly easily and ignore the type-acceptance rules nonsense. The radios will function perfectly on MURS (or F/GMRS). No one will know. No one will care.
jaspence
Michigan
When you are letting young grand children use the radios, a Moto is out of the question. Six months later they are still being used, and no one worries if they do get lost or broken. You may consider them junk, cmdrwill, but common sense says you don't put a brick like the XTS in the hands of a child.
jaspence
Michigan
Outerdog, those radios are VHF only and will not work on FRS or GRMS that are on UHF.
lb2910
Washington DC
Yup.. the ones I have are only VHF.. I actually DO have a GMRS license from the FCC. But the 400MHz band isn't as good in the outdoors as the VHF band. Hence me getting the XTS VHF radios.
Giddyuptd
Here and there
I know a guy that apx7000s for his license use and his kids use them on their license. Some can afford the oh well if it breaks.
lb2910
Washington DC
Since I clearly have a lot of experience on this thread... is it worth it to look into getting my own VHF freq?? I know that it can be expensive and take some time, but if I can use the freq however I want, maybe its worth it???
Outerdog
T¹ ÆS Ø
No. Just use MURS.
And I made a mistake earlier too. MURS is licensed by rule which means you can use it without obtaining a license. I'm not high up on Brain Mountain today, it seems.
