New here
Jill39
morgantown wv
The most common problem with scanners is bad or corrupted SD cards. I would try a new card to see that that solves the problem. If the scanner is new and in warranty, I would contact Whistler tech support and notify them of your problem. It shouldn't be doing that.
That is what i plan on doing. The scanner came on and started scanning like it should today, but i am going to contact whistler and get a new card just in case. The scanner is a week old.
Jill39
morgantown wv
Your file shows you are using scan lists 1, 2, 152, 153, 154, and 159. Scan lists 1, 151, 152, 153, 154, and 159 are enabled in the file. With just scan list 1 enabled, you should receive all of the talkgroups except WVU PD and WVDnr. Scan list 152 needs to be enabled to receive WVU PD and WVDnr. Scan lists 152, 153, 154, and 159 need to be enabled to receive all of the conventional frequencies. You can change the scan list numbers for each talkgroup and conventional frequency.
Ok under general settings i see that what you are talking about. What i thought were channels in a scan list is actually a scan list for each object and not a channel. i think i am saying that right.
I went to the weather tab and checked a frequency and entered a SAME location code for my area. If i enable them and then go to the scan list and enable sw should that work to get alerts on my scanner?
tvengr
Well Known Member
Baltimore County, MD
I haven't been using weather on my WS1080. I'll read the TRX-1 manual and get back to you.
