New Jersey Interoperability Communication System (NJICS)
rr60
I can also confirm that Somerville and Perryville assigned troop car mobiles have begun receiving new programming.
Indeed. This afternoon, Site 1, 2, 7, 8, 28, all carrying B2-5 traffic. Have not seen activity like that before. Radom site activity w B2-5 been slowly increasing, but not seen widespread like this.
W2SJW
Senior Member
Northwest NJ
As per my friend at Motorola, the systems will remain separate during the upgrade process, with continued patching as needed via the core cross-connects. The major work should begin sometime around the end of Q1 2021.
When all is said & done, the new system will be 100% integrated with the NJICS. Those that monitor the system on UniTrunker & other similar apps will only need 2 dongles to keep track of things when the upgrade is complete.
I'm a little suspect about the 6000's, unless those were bought a long time ago & kept in storage. Moto is really only pushing the 8000 & 4000 portables these days (6000 & 7000 are EOL).
GTR8000
NY/NJ Database Guy
BEE00
The 6x00 series is very much still a current product, with the 6000 BN revision released just a couple of years ago (based on the 8000). The BN mobiles were released this year, including the 6500 series. The 7x00 series has been EOL for a number of years.
GTR8000
NY/NJ Database Guy
BEE00
NJSP South Simulcast = NJICS Site 10
NJSP North Simulcast = NJICS Site 11
NJSP Central Simulcast = NJICS Site 12
NJSP IR's = NJICS Sites 41-54
That's a tiny bit misleading. Those site numbers are not actually part of the NJICS ASTRO 25 core, but are unavailable to use on the NJICS currently due to the SmartX site converters tying the two systems together. The site numbers have to be unique across both system, hence the gaps in the NJICS site numbering due to the existing SmartZone site numbers.
Trivia: Why did they start the SmartZone numbering at Site 10? Because 10 in decimal value is A in hexadecimal, 11 is B, and 12 is C...matching the NJSP Troops.
RadioDitch
Field Operations Member
Not Where You Think
Thanks for the correction/lesson.
K2NEC
5F6
Right. I know someone that bought a bunch of 6000's fresh from Motorola fairly recently. It's not all just the 8000's now that they discontinued the 7000 series.
W2SJW
Senior Member
Northwest NJ
Thanks for the clarification on that. I had no idea they moved into a BN revision for that model.
I remember dealing with that years ago on the XTS2500's...
RadioDitch
Not Where You Think
Long Branch (Site 39) is now NAC397, as expected. Update submitted.
No changes to Bordentown, New Brunswick, STR-II, Union County, or West Orange.
STR-I not deployed.
rr60
STR-I not deployed.
I am finally off Uniden and on a SDR stick with UT. Fantastic difference on NJICS. Attack time and decode much improved. I too had a look around. Pulled in
Bordentown, Telegraph Hill, Cranbury, Freehold, Martinville, Rutgers, Union County and Hunterdon all in order as @RadioDitch observed.
I did note a Union Twsp 2019xxx get denied on Site (2) for TG4679. Also noticed a Peers question or perhaps better stated a question on two sites.
Sites 27 & 28 ( Martinsville & Walpack) on UT and the DB show they use the same CC and site frequencies. I assume they are not Simulcast. Is it the terrain between the two sites what makes this possible? I do see the NAC different as well.
RadioDitch
Not Where You Think
No, they are not. Walpack will be come part of the Sussex Simulcast with High Point and Bearfort Mountain once Bearfort Mountain is constructed, on air, and ready to go.
GTR8000
NY/NJ Database Guy
BEE00
Hamburg Mtn is the third subsite of the future Sussex simulcast, not Bearfort (which is in Passaic and will be part of that simulcast).
Distance and a different NAC are what make it possible for 27 and 28 to share the same frequencies. At one point 25 and 26 also had identical lineups. Sites 26 and 27 always had unique NAC from the rest of the sites, even prior to this most recent realignment, for just that reason.
RadioDitch
Not Where You Think
Holy freaking brain fart. Sorry, been up for two days with work. Not sure how the hell I crossed those wires. I of all people should know better.
GM
Site 18: Millville is now NAC 392. Database submission has been made - update notes, scanners, data slicers, and equipment as necessary.
RadioDitch
Not Where You Think
Still on the expected pattern. West Orange, Bordentown, Union County, New Brunswick, and Penn Station are all that remain to be changed. Assuming of course the simulcasts will change.
richee2000
New TG 5161 on Union Co site, doing a Fire Dept Roll Call. (no Radio Ids observed)
N2NHL
Belleville, NJ
I also heard TG 3137 on UC Simulcast this morning. Sounded like fire activity on a highway, but something about spraying foam on the highway was mentioned. But I guess it could have also been DOT. I'm not sure.
rr60
I suspect you heard Plainfield Fire. They were reported on 5163 over on the municipal migration thread. They are all ICS able now. Likely both 5161 and 5163 are Plainfield Fire.
With some RID’s a DB sub could be made. I have no UT access presently.
