Anybody notice the West Mesa site appears to be down? Haven’t heard a control channel in a few days and checked all of the frequencies for that site. Can anyone else confirm?
Thank you both for the info -- do you know if in the manual it shows how to change the Control and ALT control channels on the 436? or can that be done though the Sentinel - I assume Sentinel loads up just like the provoice program did.Btw you only need to enter the control and Alt control channels for each site and will work just fine.
OK I think I understand. I can go into Sentinel and add those control channels in or I can enter them into the radio manually ?Looking at the system page (to go by) New Mexico Statewide Public Safety Radio System Trunking System, Various, New Mexico - Scanner Frequencies the Control Channel is in red and alternates are in blue. Those are the only ones that need programming as they control channels assign the voice frequencies themselves. The changes can be done at the "Site Level" on Sentinel and in the radio.
OK I will give it a try. Thank you.You can add/edit/delete frequencies in both. You just need the red CC and blue alternate CC's.
Ive got whatever it came with. Had provoice added.You need the Sentinel for the SDS series and the 436/536 series, the Homepatrol software is the wrong version.
alright, I somehow got it to work. I'm picking up APD, AFR, BCSO so far. When a unit keys up I get the TGID which starts with 14 so I must be on the right system. Is there a way to change those ID #'s to read what area command I'm getting? I went though Sentinel and didnt find anywhere to change that.You will need to create a new favorites list for the NM Statewide P25 system first. Then you can select the system in the list of statewide systems under Bernalillo county, NM and add to the new favorites list you just created. You can then L/O any channels or departments you don’t want to listen too. Make sure to hit updates first to A) update and download any new firmware that might be available via the Uniden site. B) download any new DB library files that might be available on the Uniden site.
FYI - It’s not actually written to the scanner internal SD card until you select “write to scanner” from the drop down in Sentinel. Do this after you create what you want and ready to download your custom list to th scanner.
