I have one of the older Radio Shack 800 antennas. But I am pretty sure it’s a Remtronix just branded as Radio shack.
Either way it works great on trunked 700/800/900 systems.
Corwin,
Pretend X2 doesn't exist. All new P25 sytems are standard. You scanner will decode TDMA TGs all by itself. There is nothing you need to do.
Same here. 14610 BCFD Dispatch has been silent the last week. Can only here the dispatch on the ProVoice system. They may have just been testing and or still fine tuning as the system is still being rolled out. Don’t think this TG will be encrypted. I might be wrong but this is my guess as they tweak and switch over things.
Also, Corwin exactly like Erik said above, I have both my 436 & 536 programmed as a standard P25 system for the NM DTRS. It decodes any new TDMA TG’s on its own along with standard Phase 1 audio. As long as you have the search option turned on in Sys Options for that system you will hear any new unidentifiable TG’s that are TDMA as well.
This is where a single band 700/800Mhz antenna can really help pull in D2 signals.
These work great. Recommend for 700/800 reception.
On Set Remtronix Scanner Antenna
On-set Remtronix police scanner antenna for all police scanner radios. 7" whip antenna for BNC or SMA inputs. View all police scanner antennaswww.zipscanners.com
So, in other words, if you're in the city, you need to monitor all the sites for the city to NOT miss anything. AND, there should be no simulcast distortion issues requiring an SDS radio?
Great question point Chris as for I myself was wondering too, if I was going to have to save up for & purchase one of the latest Uniden SDS Scanner Models to be able to monitor the BCDF's on the NM DTRS System for my own needs & safety? I'd rather not have to purchase a SDS200 just to allow myself to monitor & listen the BCFD's on this new Statewide Digital Motorola Trunked System. Therefore, I am curious on that too Chris.
The G4 isn’t a full blown scanner though
is it?
If you have a scanner now that can monitor Phase 2 P25 you won’t have any issues monitoring the new NM DTRS 700 System including the Simulcast sites when they go active unless you just want an excuse to buy a new scanner Christmas present for yourself. 😉
