TwoToneDetect New TwoToneDetect in the works - Python based
joey9797
Benton MO
I have recently upgraded the computer at the fire station with a Windows 7 home 32 bit machine, and put TTD v68 on it, plugged the audio into the aux port, but it will not run, its just keeps coming up with the audio device not found error, I have tried the mic input, verified the speaker output is plugged in and works, tried running as administrator, also ran debug, just wont start Does anyone have any ideas for to get this working?
webby52
Hopewell, NJ
I'm still having trouble getting v69a to run. I put it on my live machine and when I try to start the program I have to try 3 or 4 times before the program runs. It does not run on every execution of the program file. I went into doss and ran the debug version 5 times in a row and it worked all 5 times. I went back to my TTD program folder and tried to run v69a 3 times in a row and it did not open on those 3 tries. I went to my v68 folder and tried v68 and it opened first try. Went to my v69 folder and ran v69 and it opened first try. Went back again to my v69a folder and tried 3 times and it did not open. Each version folder is in the same directory.
I tried checking the log file, but there is not a log file for the times that the program does not successfully open. Also, I had copied my config.cfg and remote.cfg from v69 to v69a so the settings are the same in both versions. I removed my config.cfg and remote.cfg and put back the program originals and v69a still does not open on every execution of the program file. Not sure why I am having this issue.
This in running on Win7 pro 32 bit. The program seems to work every time on my Win10 pro 64 bit computer that I tested it on.
Marvin
I've had this problem too. 69a won't run with v68 also running. I have to start 69a first, then v68.
aaknitt
Did you try the 69a alternate build that Andy posted, it fixed my issue.
I'm also curious about this. If the 69a alternate build is working for you, I'm going to go ahead and release 69 using that build. If not, I may have more work to do.
Andy
Westernbound
Dickens TX
Andy
It is working fine, 69a alternate build has started first time every time. I have been running it on my live machine since you posted it, and I have had no problems with it.
Marvin
Westernbound
Dickens TX
Andy
Also, I was just wondering why the label of the TTD window does not include the letter of the version number (69a) instead of the plain number (69). I know it was not included in 65c, 65d, or 67a. When I was testing between v69 and v69a I became confused as to which window I had open since they were labeled the same. I had to use the new "instance_id" field to label them so I could tell them apart. Not a big problem, but just wondering why the letter is not included.
Marvin
motomeso
Ontario
HI Andy,
I had a few pages fail last night during their weekly testing. This is the error in the log file.
Traceback (most recent call last):
File "<string>", line 599, in mail
File "smtplib.py", line 251, in __init__
error: [Errno 10061] No connection could be made because the target machine actively refused it
There would have been 6 or so stations stacked with fire and officer pages.
aaknitt
HI Andy,
That error typically means that there is a problem with the email server that TTD is trying to communicate with. It's able to talk to the server, but the server is saying "get lost".
Andy
steve0622
Wichita Falls, TX
I have had a strange issue show up on TTD68. I run 7 departments off 1 install (all departments on same paging frequency just different A and B tones). I have 1 department that has stopped recognizing their tone pair. I loaded Audicity and verified that the A and B tones have not changed. I have ran the debug to see what tones TTD is seeing, and it is not detecting the A tone, but it is detecting the B tone. My tone tolerance is set for 3.0 A tone length set to .1 and B tone length set for 3. My B tone length was set to 1, but I had the same issue with a different tone set last year and moved B tone length to 3 and haven't had any other issues with the other tone set. The set that is causing an issue now, I moved to 3 B tone as well, and have moved scanner location, as well as reloaded TTD and still having the same issue with the 1 tone set not being regonized. All 6 of the other departments are working as it should no issues. Has anyone had this issue before? Do I need to take the 1 tone set that is not working and move it to long tone instead of A B tone?
DC31
Massachusetts
can you post a couple snippets from the logfile showing where the No. 1 tone set is being missed and another showing where one of the other tone sets is being detected? It may be an audio threshold setting issue.
The snippet for a successful decode would look like this:
Freq: 763.0 Level: 6479.42906036
Freq: 1301.0 Level: 2027.42770977
Freq: 1613.0 Level: 1619.57358305
Freq: 763.0 Level: 3450.32307301
Freq: 1457.0 Level: 1579.37224544
Freq: 1150.0 Level: 25891.9838943
Freq: 1150.0 Level: 22556.2964259
Freq: 1150.0 Level: 22900.2445713
Freq: 1150.0 Level: 22571.9877718
Freq: 1150.0 Level: 22754.193024
Freq: 1150.0 Level: 25839.7937665
Freq: 1123.0 Level: 22743.396259
Freq: 1123.0 Level: 23039.3961374
Freq: 1123.0 Level: 23570.8107599
Freq: 1123.0 Level: 24100.4865037
Freq: 1118.0 Level: 23829.6772592
_Fire Tone Set Found
delay timer _Fire 07:32:36 on 02/16/17
0.0
delay done _Fire 07:32:37 on 02/16/17
waiting for audio _Fire 07:32:37 on 02/16/17
mono
Freq: 1123.0 Level: 22958.8532847
Freq: 1123.0 Level: 23562.3464132
max(audio_data) for _Fire = 23695
threshold exceeded
recording audio _Fire 07:32:37 on 02/16/17
iterations: 200
Freq: 1123.0 Level: 23106.8030477
Freq: 1123.0 Level: 22894.7127799
Freq: 1123.0 Level: 23164.3850836
Freq: 1123.0 Level: 23213.3041093
Freq: 1123.0 Level: 23073.4586711
Freq: 1123.0 Level: 23972.1917592
Freq: 1123.0 Level: 23025.9895673
Freq: 1123.0 Level: 22948.0811071
Freq: 1123.0 Level: 22927.0599033
Freq: 1532.0 Level: 1492.59604032
Freq: 656.0 Level: 3407.80516826
Freq: 1193.0 Level: 1817.33187359
Freq: 349.0 Level: 1558.29687009
Freq: 994.0 Level: 5831.2761227
Freq: 349.0 Level: 1848.93191991
The failed decode will be harder to find but you will need to look for the repeating freq showing it is hearing the tones.
Is the Atone that you are missing a low freq tone? Something around 300 hz? I have trouble with those.
mattnelson26
Hopkins, Minnesota
What kind of error is this and why wont it send.
done converting to AMR HOPKINS DUTY CREW 12:40:20 on 02/16/17
2613.0 315.48025836
2613.0 358.220400507
File "<string>", line 605, in mail
File "smtplib.py", line 615, in login
SMTPAuthenticationError: (535, '5.7.8 Username and Password not accepted. Learn more at\n5.7.8 https://support.google.com/mail/?p=BadCredentials m79sm3588234ioo.0 - gsmtp')
Email not sent on attempt 1trying again in five seconds for HOPKINS DUTY CREW page received at 12:39:45 on 02/16/17
2613.0 378.613267526
2613.0 338.0499726
768.0 6931.5291917
1209.0 7012.44183588
1209.0 7559.73444197
1333.0 7990.95354678
1204.0 1258.69644199
2613.0 330.651851876
2613.0 522.264076082
2613.0 301.045515098
2613.0 324.242838211
2613.0 316.871167014
2613.0 332.3835663
645.0 5793.71131693
645.0 5824.0276267
645.0 5784.41189801
645.0 5789.29427777
645.0 5806.76144203
645.0 5747.37149942
344.0 1805.77987317
344.0 1710.29344687
344.0 1870.33706723
344.0 1809.3134557
344.0 1872.55256426
344.0 1697.78981669
344.0 1905.31286871
344.0 1745.40889739
344.0 1949.32511256
SMTPAuthenticationError: (535, '5.7.8 Username and Password not accepted. Learn more at\n5.7.8 https://support.google.com/mail/?p=BadCredentials p19sm1923265iod.48 - gsmtp')
Email not sent on attempt 2trying again in five seconds for HOPKINS DUTY CREW page received at 12:39:45 on 02/16/17
344.0 1788.98027498
steve0622
Wichita Falls, TX
first snipit is the one that is not being detected A tone 2804 B tone 1177
Succesfully retrieved local tone info
Tone1
Tone2
Tone3
Tone8
Tone9
Tone10
Tone11
Longtone1
1177.0 6639.55312939
1177.0 13602.915789
1177.0 13447.6099549
1177.0 13399.6388229
1177.0 14281.1746903
1177.0 13248.9619607
1177.0 14106.6297117
1177.0 13982.6589235
1177.0 13745.6844409
1177.0 13631.3770324
1177.0 13872.1359988
1177.0 13288.4672166
1177.0 13581.3435846
1177.0 13491.9342176
1177.0 13549.4113375
1177.0 13914.0878838
1177.0 13530.8054231
1252.0 6529.598792
263.0 32766.9822488
252.0 32766.9822488
629.0 422.879556949
1650.0 3295.39012044
650.0 24111.6867902
1710.0 6153.38189701
1581.0 24430.1098387
next snipit is from a sucessful tone. A Tone 564 B Tone 1231
564.0 617.605546462
564.0 18147.3512379
1231.0 22072.4280568
1231.0 22369.1746013
1231.0 22467.5851969
1231.0 22724.2199438
1231.0 22689.2341539
Iowa Park VFD Tone Set Found
delay timer Iowa Park VFD 22:57:03 on 02/07/17
I have noticed on the fire pagers and on the radios that the A Tone 2804 sounds a lot shorter than it used to. In the settings i have A Tone at .1 and B Tone at 3
DC31
Massachusetts
Tone1
Tone2
Tone3
Tone8
Tone9
Tone10
Tone11
Longtone1
1177.0 13602.915789
1252.0 6529.598792
263.0 32766.9822488
252.0 32766.9822488
629.0 422.879556949
650.0 24111.6867902
564.0 617.605546462
564.0 18147.3512379
Odd that the system isn't even hearing the Atone but is getting the Btone real solid. Standard timing is a 1 sec. Atone and 3 sec. BTone. How short do you estimate the recent Atone is? Your successful snippet shows only two samples of the Atone. Each sample is 200 ms (.2 sec.)
Changing to a Long Tone won't work because that looks for a minimum of 4 sec. tone length. What should work as a temporary fix is to set both your Atone and your Btone to 1177 hz with tone lengths of 1 and 1. It will decode the first five samples of the 1177 as Atone and then the second five samples of 1177 as Btone. Not ideal, but I bet it will work. As long as no one else in your setup uses the 1177 Btone.
steve0622
Wichita Falls, TX
The new Atone as far as I can tell is about 1 sec it used to be 2 or 3 sec. That is an interesting setup for setting both tones the same, and I will give that a try and report back. Thanks for the advise.
DC31
Massachusetts
In your snippet you have 17 samples of the 1177 Btone. Fifteen 200ms samples would be three seconds. So that Btone is very close to the standard 3 second timing.
On your Iowa Park decode it only shows two samples of the Atone. A one second Atone would normally show 5-6 samples.
In your configuration file, what is your audio threshold setting?
You might also try turning your scanner/radio volume up a little. That might help it pick up the Atone.
You aren't feeding the audio in from a scanner that is scanning multiple frequencies are you?
steve0622
Wichita Falls, TX
The scanner only has the one frequency for the fire departments programed in. All the fire departments are paged out on the same frequency. So, the scanner is not scanning, and it is manually set on the channel with no ctcss..its set as open squelch. For all the departments, A Tone Length is set to .1 and B Tone length is set to 3 or 1 Tone Tolerance is set to 3.0 Tone Offset is 0.0 and Audio Threshold is 69.
putterizer
WI
2613.0 315.48025836
2613.0 338.0499726
768.0 6931.5291917
2613.0 332.3835663
645.0 5793.71131693
645.0 5824.0276267
645.0 5784.41189801
645.0 5789.29427777
645.0 5806.76144203
645.0 5747.37149942
344.0 1805.77987317
344.0 1710.29344687
344.0 1870.33706723
344.0 1809.3134557
344.0 1872.55256426
344.0 1697.78981669
344.0 1905.31286871
344.0 1745.40889739
344.0 1949.32511256
344.0 1788.98027498
The error says your username and/or password is wrong. That is why it won't send out.
