TwoToneDetect New TwoToneDetect in the works - Python based
mattnelson26
Hopkins, Minnesota
i just switcched to TTD70v and am getting this
Traceback (most recent call last):
File "TTD70.py", line 72, in mail
File "smtplib.py", line 256, in __init__
SMTPServerDisconnected: Connection unexpectedly closed: timed out
Email not sent via smtp.gmail.com on port 465 using STARTTLS on attempt 2 trying again in five seconds for ST_ LOUIS PARK STATION 1 Page Received at 17:40:21 on 01/08/18
jhsands
Texarkana, Arkansas
Do you use an internet security product that blocks smtp on programs by default?
Sent from my Galaxy S7
motomeso
Ontario
Yes I’m running a primary and secondary VM with 6 instances of TTD and 6 VFO’s using an RTL SDR on each server. The primary and backup TTD instances communicate via an FTP server setup on my DNS-320L NAS drive.
ajalbarano
Duncansville, PA
1] I have 17 channels on pushbullet and have not had an issue.
2] It's pretty convoluted on getting the group key IMO. Getting the app_token is pretty straightforward. I'd like to see if you can get it working as I had an issue with it keep giving me an SSL error.
Mine shows the error, channel tag does not exist. One day a particular station will work fine and the next day or even next dispatch (its random) it won’t. Have you seen this happen? Any idea why it would do that?
ajalbarano
Duncansville, PA
I have successfully tried them both and have settled on pushover as my preferred app. The number of departments that you are serving shouldn’t make a difference.
I found pushover to be a little more intuitive (neither is particularly easy to set up) and to have a much better set of features. (With pushover, you can even set a high priority alert that will repeat until the subscriber acknowledges it.)
Right now, I am testing Andy’s TTD installer for the pi. It is sending pushovers fine but I am getting an error on pushbullet that i am trying to figure out.
I don’t understand. One day it will work and the next it won’t. I thought maybe pushover May work better. Is it a lot harder to set up? Any idea why this is happening with pushbullet?
jhsands
Texarkana, Arkansas
Did you make your channel with a #? If so, you have to put the # as the channel. I created mine without the tag.
ajalbarano
Duncansville, PA
No. Should I be putting the channel names and not the tag? It works with the tags but randomly won’t work. When I tried channel name at first, it didn’t work at all. Should I create a channel without a tag and put channel name?
DC31
Massachusetts
Can you post the logfile entry showing where a tone set was decoded but failed to send to pushbullet?
Are you getting indication in the TTD window that PB is sending?
DC31
Massachusetts
Are you sure that the issue is with TTD and not with your phone? When I set pushbullet up, i got nothing on the phone until after I had power cycled it.
Try power cycling your phone if you haven’t already.
I have had zero problems with Pushover. Neither is easy to set up.
I have about 50 tone sets going to pushover with at least a couple hundred subscribers. Sending probably 20-30 alerts a day. I have a separate PO app for each tone set and haven’t yet come close to the 7500 monthly limit/app on the free service.
ajalbarano
Duncansville, PA
I am sure. And I’m having issues right now with computer but the error is seen in the TTD DOS Script and says, pushbullet No channel found with Channel_tag “blueknob”
DC31
Massachusetts
I set up TTD to send me pushbullets this morning as well as the usual emails and pushovers. Yes, I can confirm that receiving pushbullets is hit or miss. Occasionally, TTD indicates pushbullet sent but it never gets to my devices.
ajalbarano
Duncansville, PA
TTD isn’t sending it. It’s not getting to pushbullet. And that is hit or miss
jhsands
Texarkana, Arkansas
Look at your console. Is it #blueknob or @blueknob?
aaknitt
Port 465 is usually SSL, and port 587 is usually STARTTLS. Try SSL instead of STARTTLS in your Edit Config menu, restart, and see if that does the trick.
Andy
ajalbarano
Duncansville, PA
Here is one that did NOT work, even though this channel tag does exist and it has uploaded to it SEVERAL other times.
Bald Eagle Station 36 Tone Set Found
after record
delay timer Bald Eagle Station 36 19:56:17 on 01/13/18
1183.0 15398.9101078
2.5
1183.0 2400.83071763
1183.0 2628.34086045
1183.0 2381.33779772
1183.0 2394.977482
1183.0 2485.16541959
1183.0 1739.51503995
1183.0 1754.88496127
1183.0 1737.91364328
1183.0 1703.09844662
1183.0 1762.82963281
1183.0 1697.00970833
1183.0 1715.99163336
delay done Bald Eagle Station 36 19:56:20 on 01/13/18
waiting for audio Bald Eagle Station 36 19:56:20 on 01/13/18
threshold value: 1448.15468787
mono
mono
mono
mono
mono
mono
mono
threshold exceeded
recording audio Bald Eagle Station 36 19:56:21 on 01/13/18
iterations: 200
747.0 11066.528112
1199.0 14030.4418492
1199.0 14160.2717434
1919.0 1067.83879319
1376.0 9309.77428892
1957.0 2565.56632049
1656.0 12052.532629
1844.0 11003.6993593
1468.0 11350.3075089
1532.0 16265.6463509
1215.0 12593.4267383
618.0 11906.4775168
1693.0 7431.13601448
2285.0 4330.869748
1435.0 11910.63802
1575.0 9810.90539395
2000.0 10287.7302132
1468.0 5018.08765174
570.0 2724.62774324
1097.0 7347.25433531
1581.0 952.090499664
1548.0 8499.82352904
1715.0 9010.41274811
1892.0 1727.23733139
1667.0 1426.90332058
1295.0 9647.77634799
Waiting for Silence Bald Eagle Station 36 19:56:40 on 01/13/18
Done recording Bald Eagle Station 36 19:56:43 on 01/13/18
done writing WAV Bald Eagle Station 36 19:56:43 on 01/13/18
done converting to MP3 Bald Eagle Station 36 19:56:44 on 01/13/18
done converting to AMR Bald Eagle Station 36 19:56:44 on 01/13/18
setting mail server up
set up mail server
starting TLS
done starting TLS
logging in
logged in
MP3 Group Email sent to trigger@applet.ifttt.com via smtp.gmail.com on port 587 using STARTTLS Bald Eagle Station 36 Page Received at 19:56:17 on 01/13/18 19:56:47 on 01/13/18
File "TTD70.py", line 240, in pushbulletsendfile
File "site-packages\pushbullet\pushbullet.py", line 206, in get_channel
PushbulletError: No channel found with channel_tag "baldeagle"
Nowco21
Judsonia, AR
I have the same issue, I have tried port 465 SSL and 587 STARTLS and neither one will work.
