Ok so 25 answers. Turn off SSL and STARTTLS and try sending on just port 25.
Waiting for Silence Nowco 19:50:14 on 01/16/18Ok so 25 answers. Turn off SSL and STARTTLS and try sending on just port 25.
I'm not sure about that, and I don't know if it matters but I can send emails through this isp on outlook and ios mail using the same smtp server settings.I wonder if it's possible the mail server isn't answering fast enough so 5 seconds timeout is too fast.
Login/Password issue? Maybe it doesn't see TTD as a proper mail client.
[Section1]
email_user = ttd@ttd.example.org
email_pwd = dHgvdJ9uXTI= ;
email_server = do.example.com
email_port = 587
email_security = STARTTLS
email_authentication = 1
I confirmed the password is encoded correcttelnet smtp.nowcofire.org 587 shows the mail.hostingplatform.com banner, so SMTP is *not* being intercepted by your ISP.
make sure your password is encoded:
ValueError: list.remove(x): x not in list
Code:ValueError: list.remove(x): x not in list
Do you have an email in your exclude list but the e-mail is not in a to list?
NOwCo,
After making changes in the Configuration window are you clicking on Save and exit, and then exiting TTD using the exit button and restarting TTD?
The configuration changes are only loaded on a restart of the program. And they are only saved if the exit buttons are used, not the X in the corner of the window.
There are not any emails in the excluded list.Yep I made that mistake before.
Hey aaknitt
Is there a way to edit what text and link are sent to push bullet. Find on my S7 Android that I can't always download the file from pushbullet so I would like to include a link to the file I have FTP uploaded.
@Verizon Superbowl ad says it's their job to make sure first responders get the call, yet they're the one carrier that routinely blocks messages from TwoToneDetect, a program designed to do exactly that.
That's awesome!I'm not much of a social media poster, but Verizon's Superbowl ad prompted me to post this:
Feel free to do likewise
Andy
Your account must be private. I searched for TwoToneDetect and last one is from 16 Apr 2016.That's awesome!
I'm still having trouble getting v69a to run. I put it on my live machine and when I try to start the program I have to try 3 or 4 times before the program runs. It does not run on every execution of the program file. I went into doss and ran the debug version 5 times in a row and it worked all 5 times. I went back to my TTD program folder and tried to run v69a 3 times in a row and it did not open on those 3 tries. I went to my v68 folder and tried v68 and it opened first try. Went to my v69 folder and ran v69 and it opened first try. Went back again to my v69a folder and tried 3 times and it did not open. Each version folder is in the same directory.
I tried checking the log file, but there is not a log file for the times that the program does not successfully open. Also, I had copied my config.cfg and remote.cfg from v69 to v69a so the settings are the same in both versions. I removed my config.cfg and remote.cfg and put back the program originals and v69a still does not open on every execution of the program file. Not sure why I am having this issue.
This in running on Win7 pro 32 bit. The program seems to work every time on my Win10 pro 64 bit computer that I tested it on.
Andy
I am having the same problem with V70 that I had in V69. TTD will not open on every execution of the program file. Tonight it took 3 tries on my Win7 machine for TTD to start, 5 tries on my Win10 machine. On the Win7 machine, the program dies right after the 2nd instance of TTD appears in task manager, but before it pulls my remotely hosted tones file and it does not create an entry in the log file.
Marvin
start "" /HIGH /D "C:\Users\Owner\TTD69" "C:\Users\Owner\TTD70\TTD69a.exe"
