TwoToneDetect New TwoToneDetect in the works - Python based
jhsands
Texarkana, Arkansas
For those that are seeing this issue, is it Windows, Pi, or both? Does the tone detection still function when this occurs?
FYI I've identified a bug that can cause TTD to crash after it's generated a large amount of audio files...typically several weeks of operation on a busy system without restarting. I have a fix in testing now that should be out soon. One symptom of this issues is that the web page doesn't work, but neither does tone detection. If there's a different issue where the web page doesn't work but tone detection does, that's something different I'll need to look into.
Andy
Tone detection works fine; 404 error.
aaknitt
Same. As far as I know it's working fine in the background but when trying to bring up the webpage to manage settings I get a 404 error. Usually restarting the program or the PC solves it.
Ok. And are you attempting to open it by clicking on the icon in the system tray or by going to the URL some other way (bookmark or manually entered)? One thing to try is manually incrementing the port number in the URL by one in the browser address bar...if the port that TTD is trying to use is blocked for some reason during startup it will attempt to try the next port. Wouldn't really explain what's going on if it was working and then stopped though.
Andy
Deziel0495
PE/NB Database Guy
PEI
Andy
I get it by clicking the icon in the taskbar to open the management page, not sure about the others. It is using the default port as far as I know and working fine in the background. Just when I try to open it I get the 404 error but it keeps working to my knowledge. A simple force restart of the program usually fixes it.
jhsands
Texarkana, Arkansas
Andy
Code:
TCP    0.0.0.0:8080           0.0.0.0:0              LISTENING
[TTD71.exe]
Code:
http://192.168.43.36:8080/index.html
Error: 404 Not Found
Sorry, the requested URL 'http://192.168.43.36:8080/index.html' caused an error:
File does not exist.
Restart the program and all is fine. I've never seen an icon in the system tray... running 71c.
WebsterEMA
I'm using it on Windows, and I'm just clocking on the tray icon. Or if the main screen is already up, I'm hitting one of the configuration buttons.
mattnelson26
Hopkins, Minnesota
Good morning all I have multiple two tones working. One is working fine no issues and another with different cities and some of the same but womt send to address and I copied and paste just changed to a and b numbers. I checked the log and says it sent no errors
DC31
Massachusetts
Your working TTD is sending individual emails and the non-working is trying to send a group email. Have you tried individual?
Mark181
Ocean County, NJ
Strange how he is unable to send the emails as BCC. I use that for all of my TTD scripts that I'm running.
I find it much faster and much less likely for Gmail to get pissed at you, lol.
Deziel0495
PE/NB Database Guy
PEI
Does anyone know if TTD could use this tone as an AB tone?
I haven't played around with it much but looking at possibly capturing pages on our P25 trunked system and they frequently use this alert tone.
DC31
Massachusetts
Ok, so that appears to be an 800/1500 hz tone set with two cycles per second. Thus, each tone is approximately .25 sec long. Try both tonelengths of 2. It may get it but won’t be very reliable
make that 0.2 tonelength
Mark181
Ocean County, NJ
When is the next version of TTD being released, and might I request a feature that will make it easier to add or remove multiple people to multiple different tone lists in one action?
cpg178
TTD was bought by I am Responding so unless you pay the big bucks your stuck with what they have now I am pretty sure.
