FVFD23
I am still using v56. It works great but every once in a while I get false messages sent to my phone/e-mail. Is this common or is there a way to adjust this from happening?
It looks like it can't find a sound card to use. If you're copying over the config.cfg file from a different computer that might cause some issues. You might want to manually set the input and output devices to 0 by editing config.cfg with a text editor. Also if it's a newer computer you may need to have a cord plugged into the audio input in order for it to recognize the sound card. Finally, you can always check the log.txt file for errors even if you're not using the debug version.
Andy
The in/out audio settings was already at "0"
The input was already occupied with the scanner
The log file from the debug is what I posted on the last message.
help?
Are you able to record from your scanner using Windows sound recorder?
Andy
Yes.
I have TTD56 on computer 1
I installed TTD63 on computer1
Configured TTD63.
Closed TTD56
Opened TTD63debug. Got a quick flash of the DOS window, which I captured a screenshot and shown here.
TTD63 closed out automatically. Nothing open or operational.
Opened up TTD56... continue to use this for past few days. Still get tons of false pages even with Btonelength at 2.9
Would like to upgrade so I can take advantage of the Atonelength feature
thanks
I just updated to v63. I am using the remote config. I just copied the tones, remote, and config files over from v61. Is that the correct way or do I need to manually re enter the information?
Yes.
Configured TTD63.
Closed TTD56
thanks
v63 should still work though. What happens if you copy the config.cfg file from v56 into the v63 folder? Will it run then?
Andy
This would be hard to get right, since if a dispatcher pauses partway through a dispatch it could terminate the recording, which wouldn't be desirable.
Andy
Andy:
New issue with running v63 alone on the computer (just updated)
All of the recordings are full of echo on v63
The v56 does not have any echo at all. Same scanner, same computer, same input, same everything.
I too am using v56 and v63. No issues until I added a ground loop isolator. Now theres no hum in the recording, but now they are both falsing big time. I went into the tones file and adjusted the btonelength to 3 and btonedebounce to 4 on v56 and upped the atone/btone length to .9 in v63. Now v63 is working no falses yet (been a few hours) but v56 wont load. I get the same window as above and although I can't provide a screen shot (and there is no log file in any of my versions) I thought I was having sound card issues as well. This seems unlikely as I am running v63, and another program and they are both recording. I checked the config file and it was set to 1 and 2 for incoming and outgoing. I changed it to 0 for both and still won't load. All I can make out is something about trace and then the window closes.
Do you have Playback During Record enabled? If so, what input are you using (what's the name of it)?
Andy
hrrm, it didn't quote the whole message.. but this was in reference to a MAXimum recording time, I'm interested in such a feature too. Some of my recipients aren't interested in receiving several hundred k of dribble from a long winded dispatcher..
Andy
Andy:
I tried to swap from Microsoft audio to realTek audio on the input and output.
---no difference. Still VERY enhanced echo sound.
Yes, playback during record enabled
Went back to V56... and no echo.
help?
As a troubleshooting step, try disabling Playback During Record and see if that gets rid of the echo. Any chance you have duplicate tone sets in your tones.cfg file?
Andy
