What operating system are you running TTD on? windows 7 32bit
What version of TTD are you running? 63
Has TTD ever work on this computer? yes
Did you run the debug version of TTD? yes
After running the debug version, what does the log.txt file have in it? (This file will have valuable information that can get things potentially resolved quite quickly.)
on dakota county one
Succesfully retrieved local tone info
Tone1
Tone2
Tone3
Tone4
Tone5
Tone6
Tone7
Tone8
Tone9
Tone10
Tone11
Tone12
Tone13
[1472.0, 1472.0, 1512.0, 1512.0, 1512.0, 1512.0, 1512.0, 1512.0, 1512.0, 1512.0,
1512.0, 1512.0, 1512.0, 1512.0, 1512.0, 1512.0, 1512.0]
[392.0, 392.0, 1511.9, 1511.9, 1511.9, 1511.9, 1511.9, 1511.9, 1511.9, 1511.9, 1
511.9, 1511.9, 1511.9, 1511.9, 1511.9, 1511.9, 1511.9]
[412.8, 412.8, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1
512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1]
[433.0, 433.0, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1512.1, 1
[810.1, 810.1, 422.7, 422.7, 422.7, 422.7, 422.7, 422.7, 422.7, 422.7, 422.7, 42
2.7, 422.7, 422.7, 422.7, 422.7, 422.7]
[810.2, 810.2, 538.1, 538.1, 538.1, 538.1, 538.1, 538.1, 538.1, 538.1, 538.1, 53
8.1, 538.1, 538.1, 538.1, 538.1, 538.1]
[810.1, 810.1, 906.1, 906.1, 906.1, 906.1, 906.1, 906.1, 906.1, 906.1, 906.1, 90
6.1, 906.1, 906.1, 906.1, 906.1, 906.1]
[1321.9, 1321.9, 512.0, 512.0, 512.0, 512.0, 512.0, 512.0, 512.0, 512.0, 512.0,
512.0, 512.0, 512.0, 512.0, 512.0, 512.0]
[1393.2, 1393.2, 485.1, 485.1, 485.1, 485.1, 485.1, 485.1, 485.1, 485.1, 485.1,
485.1, 485.1, 485.1, 485.1, 485.1, 485.1]
[952.2, 952.2, 566.4, 566.4, 566.4, 566.4, 566.4, 566.4, 566.4, 566.4, 566.4, 56
6.4, 566.4, 566.4, 566.4, 566.4, 566.4]
[952.2, 952.2, 599.9, 599.9, 599.9, 599.9, 599.9, 599.9, 599.9, 599.9, 599.9, 59
9.9, 599.9, 599.9, 599.9, 599.9, 599.9]
[951.0, 951.0, 635.4, 635.4, 635.4, 635.4, 635.4, 635.4, 635.4, 635.4, 635.4, 63
5.4, 635.4, 635.4, 635.4, 635.4, 635.4]
[360.0, 360.0, 360.0, 360.0, 360.0, 360.0, 360.0, 360.0, 360.0, 360.0, 360.0, 36
0.0, 360.0, 360.0, 360.0, 360.0, 360.0]
360.0 1564
360.0 1554
360.0 1531
360.0 1549
360.0 1561
360.0 1528
360.0 1548
360.0 1536
360.0 1541
360.0 1522
360.0 1497
360.0 1551
360.0 1525
360.0 1654
360.0 1525
360.0 1549
360.0 1549
TEST Tone Set Found
Tone1
Tone2
Tone3
Tone4
Tone5
Tone6
Tone7
Tone8
Tone9
Tone10
Tone11
Tone12
Tone13
delay timer TEST 13:04:40 on 09/24/13
'C:\test.bat' is not recognized as an internal or external command,
operable program or batch file.
delay done TEST 13:04:40 on 09/24/13360.0 1579
waiting for audio TEST 13:04:40 on 09/24/13
threshold value: 1448.15468787
starting record at 13:04:40 on 09/24/13
360.0 1532
done recording at 13:04:40 on 09/24/13
1547 max level at 13:04:40 on 09/24/13
threshold exceeded
recording audio TEST 13:04:40 on 09/24/13
Waiting for Silence TEST 13:05:22 on 09/24/13
Done recording TEST 13:05:22 on 09/24/13
done writing WAV TEST 13:05:22 on 09/24/13
ffmpeg version N-43921-ga366bea Copyright (c) 2000-2012 the FFmpeg developers
built on Aug 26 2012 20:57:47 with gcc 4.7.1 (GCC)
configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt
ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass -
-enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-l
ibfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenj
peg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
libavutil 51. 70.100 / 51. 70.100
libavcodec 54. 54.100 / 54. 54.100
libavformat 54. 25.104 / 54. 25.104
libavdevice 54. 2.100 / 54. 2.100
libavfilter 3. 13.101 / 3. 13.101
libswscale 2. 1.101 / 2. 1.101
libswresample 0. 15.100 / 0. 15.100
libpostproc 52. 0.100 / 52. 0.100
[wav @ 01febfe0] max_analyze_duration 5000000 reached at 5015510
Guessed Channel Layout for Input Stream #0.0 : mono
Input #0, wav, from './audio/TEST_2013-09-2413_05_22_212000.wav':
Duration: 00:00:41.79, bitrate: 176 kb/s
Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, mono, s16,
176 kb/s
Output #0, mp3, to './audio/TEST_2013-09-2413_05_22_212000.mp3':
Metadata:
TSSE : Lavf54.25.104
Stream #0:0: Audio: mp3, 11025 Hz, mono, s16, 32 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
size= 164kB time=00:00:41.80 bitrate= 32.1kbits/s
video:0kB audio:164kB subtitle:0 global headers:0kB muxing overhead 0.144987%
done converting to MP3 TEST 13:05:22 on 09/24/13
MP3 Email sent! TEST page received at 13:05:22 on 09/24/13 13:05:28 on 09/24/13
'c:\test2.bat' is not recognized as an internal or external command,
my other one
delay timer test 13:10:40 on 09/24/13
'c:\test.bat' is not recognized as an internal or external command,
delay done test 13:10:40 on 09/24/13
waiting for audio test 13:10:40 on 09/24/13
threshold value: 512.0
starting record at 13:10:40 on 09/24/13360.0 1514
360.0 1509
done recording at 13:10:40 on 09/24/13
1509 max level at 13:10:40 on 09/24/13
threshold exceeded
recording audio test 13:10:40 on 09/24/13
360.0 1505
360.0 1507
360.0 1487
360.0 1500
360.0 1508
360.0 1512
360.0 1532
Waiting for Silence test 13:11:22 on 09/24/13
Done recording test 13:11:22 on 09/24/13
done writing WAV test 13:11:22 on 09/24/13
ffmpeg version N-32726-ga254452, Copyright (c) 2000-2011 the FFmpeg developers
built on Sep 19 2011 19:49:13 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 16. 1 / 51. 16. 1
libavcodec 53. 16. 0 / 53. 16. 0
libavformat 53. 12. 0 / 53. 12. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 2 / 2. 43. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
[wav @ 01B08520] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 01B08520] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/test_2013-09-2413_11_22_374000.wav':
Stream #0.0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 1 channels,
s16, 176 kb/s
[mp3 @ 0285C580] Unsupported sample rate.
Output #0, mp3, to './audio/test_2013-09-2413_11_22_374000.mp3':
Metadata:
TSSE : Lavf53.12.0
Stream #0.0: Audio: mp3, 11025 Hz, 1 channels, s16, 32 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libmp3lame)
size= 164kB time=00:00:41.90 bitrate= 32.0kbits/s
video:0kB audio:164kB global headers:0kB muxing overhead 0.019690%
done converting to MP3 test 13:11:22 on 09/24/13
MP3 Email sent! test page received at 13:11:22 on 09/24/13 13:11:28 on 09/24/13
