TwoToneDetect New TwoToneDetect in the works - Python based
smyers119
New Jersey
Hi. this program was working very well for me until I switched the email address and phone number I am sending to.
Since then, not a single tone has been detected... I'm not sure why.
Any ideas?
Copy and paste your tone file or just compare to the sampletone file, also copy and paste debug output
kf4teo
shelbyville,Tn
I have a question
I have used the two tone detect for a couple of months and it works great with Verizon but i have not been able to get it to work with AT&T and Sprint Does anyone know what i need to to use.
DC31
Massachusetts
For att: XXXXXXXXXX@mms.att.net
For sprint: XXXXXXXXXX@pm.sprint.com
If those don't work, the problem is on the phone's end. Try sending both .amr and .mp3 attachments.
I have one recipient (iphone) who gets nothing at the mms email and gets an email with no attachment at XX@txt.att.net. I haven't been able to figure that one out. No undeliverables back either. It must be something in his phone or his service plan. Other than that one i have been successful with many others using the two formats.
tseymour91
possible fix
Check and see if he has app that condenses data to improve storage on iphone. Had similar issue and that was cause. Deleted app, started getting text again.
chad3405
Texas
If he has an I phone why are you sending it to txt.att.net and not mms.att.net? that will cause the audio to get lost.
Also Check and see if his service is actually ATT or if its something like straight talk or a pre pay plan. If it is a lot of those may pay or be with ATT but service is actually provided by someone else.
phillydjdan
Ok, I've been using various versions of this software for about 6 months now, and a problem has cropped up that I cannot solve. About a week ago I noticed I was not receiving any e-mail alerts. I checked my e-mail settings, but nothing appears to be wrong. This is the text copied from the debug version (e-mail addressed are edited for privacy):
1591.0 Atone1
311.0Atone2
344.0 Atone1
371.0Atone2
349.0 Atone1
354.0Atone2
349.0 Atone1
338.0Atone2
349.0 Atone1
516.0Atone2
344.0 Atone1
317.0Atone2
349.0 Atone1
392.0Atone2
666.0 Atone1
666.0Atone2
A Tone Found! 17:32:56
Checking for B Tone 17:32:56
Checking for B Tone2 17:32:57
Tone Set Found! 17:32:57
Sta 8 (Penndel) 17:32:57
b***************e@mail.com, s*******t@aol.com
delay timer 17:32:57
waiting for audio 17:32:59
recording audio 17:33:06
650.0 Atone1
328.0Atone2
650.0 Atone1
414.0Atone2
661.0 Atone1
440.0Atone2
666.0 Atone1
1140.0Atone2
887.0 Atone1
1183.0Atone2
349.0 Atone1
301.0Atone2
344.0 Atone1
328.0Atone2
424.0 Atone1
408.0Atone2
done writing WAV 17:34:01
ffmpeg version N-34704-g985e768, Copyright (c) 2000-2011 the FFmpeg developers
built on Nov 11 2011 01:46:59 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 24. 1 / 51. 24. 1
libavcodec 53. 31. 0 / 53. 31. 0
libavformat 53. 20. 0 / 53. 20. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 47. 2 / 2. 47. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
[wav @ 020B95C0] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 020B95C0] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/Sta_8_(Penndel)_2012-08-2417_34_01_055000.wav':
Duration: 00:00:55.72, bitrate: 352 kb/s
Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 2 channels,
s16, 352 kb/s
[mp3 @ 021DD0A0] Unsupported sample rate.
Output #0, mp3, to './audio/Sta_8_(Penndel)_2012-08-2417_34_01_055000.mp3':
Metadata:
TSSE : Lavf53.20.0
Stream #0:0: Audio: mp3, 11025 Hz, 2 channels, s16, 64 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
size= 436kB time=00:00:55.84 bitrate= 64.0kbits/s
video:0kB audio:436kB global headers:0kB muxing overhead 0.007386%
done converting to MP3 17:34:02
344.0 Atone1
489.0Atone2
344.0 Atone1
451.0Atone2
349.0 Atone1
349.0Atone2
Can someone please help me get my alerts back???
phillydjdan
I found the problem on my own. I updated the version of FFMPEG I was using and checked my e-mail settings again. No more errors appear in the debug version.
aaknitt
Matt,
Are you running the .exe file or the .py file?
Andy
aaknitt
I'm not sure what the problem might be. It seems related to pyaudio, I'm wondring if it can't find your sound card?
Andy
mattnelson26
Hopkins, Minnesota
I also tried reinstalling 54 and 55 versions and it didnt work. but i do have 56 and that works but i need three different programs. do to 3 different inputs.
thanks,
matt
iamhere300
Chappell Hill TX
Is there anyway to send the alerts to multiple recipients, without sending everyones address? Presently everyone sees who all gets the alert. I have had requests that not be the case.
krokus
Southeastern Michigan
Send the mail using the BCC field for the list, and the sending address as the recipient address. People will only see the sending address and their own.
