Hi all -
Update available! 3-2-1 GO!
HAPPY SCANNING!
TRX-1 and TRX-2 PC App
Version 3.3 - March 1, 2017
•Corrected an issue with creating a new system during the import from the library process where encrypted channels were not being imported when the option to do so was enabled. This required changing how the app handled these settings internally which means that anytime the import options are changed and the OK button is selected on that screen, the selected options will be saved and used until changed.
•Updated all supported bandplans.
•Changed how the app handles entry of frequencies. Previously the app would verify a frequency to make sure it fit the scanner's bandplan and step size within that range. The app now will verify that the frequency is in the scanner's frequency range and then round off the entered frequency to the nearest frequency that matches the bandplan if necessary.
•Added the ability to sort the system listing on the Trunked Systems tab. This feature will sort the list by clicking on the column header. This action only changes the order that systems are displayed, it will not actually change the order of systems on disk.
•Updated informational message when checking for all updates.
•Corrected tab order and tab stops in the library import areas.
•Moved the Import and Clear buttons to the middle of the screens in the library import area.
TRX-1 and TRX-2 CPU
Version 5.2 - March 1, 2017
•IMPORTANT: You must update to the latest version of the TRX-1 PC software before installing this firmware update
•Add 'tune mode' via Fn+0
•Added 'search for objects' via Fn+9
•Fix garbage characters when key locked/unlocked message clears
•Changes to CAN and UK bandplans
•Distinct tones when enabling/disabling scan lists in menus
•Bug fix in 'update from library' when CONV objects have been deleted
•Fixed problem with audio after entering Playback mode via Fn+6
•Fixed problem with talkgroup and radio IDs in NXDN playback
•Zeromatic enhancements
•Code size reductions
HAPPY SCANNING!
TRX-1 and TRX-2 CPU
