I came across a VHF DMR trunked radio system in the Boston area that I thought was a Capacity Plus system at first, then I saw the Aloha messages and other trappings of a T3 system. So far all I get is an idle channel that acts like a Capacity Plus one. It looks like the system is in setup phase.
DSDPlus FL identifies it as T3nonStd (MOT) with an ID of L5-1. It appears there are two neighbors. Site 2 does not appear to be active, but Site 18 is. The LSN of Site 18 is 363, or LCN of 182, so it appears the site number is in the LCN and not base + offset based like normal T3 systems. This later changed to 365 (LCN 183). I can not hear site 18.
I am getting bursts like this:
Occasionally there is an unknown CSBK in the burst.
I wonder if anyone else is seeing systems like this?
73 Eric
Code:
2025.08.14 22:26:48 Sync:+DMR
2025.08.14 22:26:48 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Bcast Site Pri/SysCode=4 10.0101.00000001 AB; Neighbor Pri/SysCode/CC=0 10.0101.00000010 1
2025.08.14 22:26:48 +DMR slot2 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 B; Networked; Registration req'd
2025.08.14 22:26:48 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.08.14 22:26:48 SYS_Parms: SysCode=10.0101.00000001; Registration req'd; CSC=0
2025.08.14 22:26:48 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Bcast Site Pri/SysCode=6 10.0101.00000001 AB; Neighbor Pri/SysCode/CC=0 10.0101.00010010 363 ACTIVE
2025.08.14 22:26:49 Sync: no sync
2025.08.14 22:26:50 Sync:+DMR
2025.08.14 22:26:50 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Bcast Site Pri/SysCode=4 10.0101.00000001 AB; Neighbor Pri/SysCode/CC=0 10.0101.00000010 1
2025.08.14 22:26:50 +DMR slot2 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 B; Networked; Registration req'd
2025.08.14 22:26:50 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.08.14 22:26:50 SYS_Parms: SysCode=10.0101.00000001; Registration req'd; CSC=0
2025.08.14 22:26:50 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Bcast Site Pri/SysCode=6 10.0101.00000001 AB; Neighbor Pri/SysCode/CC=0 10.0101.00010010 363 ACTIVE
2025.08.14 22:26:51 Sync: no sync
Code:
2025.08.15 6:47:42 Sync:+DMR
2025.08.15 6:47:42 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.08.15 6:47:42 +DMR slot2 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 B; Networked; Registration req'd
2025.08.15 6:47:42 SYS_Parms: SysCode=10.0101.00000001; Registration req'd; CSC=0
2025.08.15 6:47:43 +DMR slot2 BS DATA DCC=5 CSBK ECC/RAS [LB=1 CSBKO=57 (?) FID=10 v16=0000 id1=1441792 id2=0]
2025.08.15 6:47:43 39 10 0000 160000 000000
2025.08.15 6:47:43 101110010001000000000000000000000001011000000000000000000000000000000000000000001001010010110010
2025.08.15 6:47:43 SYS_Parms: SysCode=10.0101.00000001; Registration req'd; CSC=0
2025.08.15 6:47:43 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 AB; Networked; Registration req'd; Ver 1.7.1; Unsynced TS; Aligned Timing
2025.08.15 6:47:43 +DMR slot1 BS DATA DCC=5 CSBK ECC/RAS [LB=1 CSBKO=57 (?) FID=00 v16=0000 id1=1441792 id2=0]
2025.08.15 6:47:43 39 00 0000 160000 000000
2025.08.15 6:47:43 101110010000000000000000000000000001011000000000000000000000000000000000000000001001000011101000
2025.08.15 6:47:43 +DMR slot2 BS DATA DCC=5 CSBK ECC/RAS Aloha SysCode=10.0101.00000001 B; Networked; Registration req'd
2025.08.15 6:47:43 Sync: no sync
73 Eric
