There is no list of radio ID's. Go into your advanced settings, (GLOB), enable Radio ID's and they will appear at the bottom of the screen as each radio enjoins the system. If you pick a transmission mid-stream the radio ID may not show. It must capture the initial "burst" to display the ID. Check in the GRE scanner board for more info.If you are looking for Talkgroup ID's look at the link that was posted.
