No more decoding with HP1
gastonet
Ciudad de Buenos Aires, Buenos Aires
Hello everyone, as maybe you can see this is my first post in this forum. I'm an old school ham operator but very new in trunked systems.
First I want to apologize if this was answered before but I've searching for an answer for my question and cant' find anything.
The problem is as follows: I got an HP1 with Extreme Update a couple of years ago wich I've used to hear the Policia Federal Argentina, wich is a sort of metro police here. Untill 2010 they was using EDACS but moved to P25 in 2011, then I started try to figure out how to heard them. I've connected Unitrunker and found (I guess) 3 sites wich they own frequencies. I can't remember how, exported that (I believe that using Butel software) to my HP1 and started to hear it. Since I've got a child in March 2012, Ive quit scanning. Now I'm returning and I can't hear almost anything on that system. Any idea?
Some tips: I didn't change anything, also rescanned the system with Unitrunker and everything seems like before. Sometimes when I tune a direct frequency I can hear voices cleary, but in scan mode (the normal operation mode) it stop scanning when found a signal but stop for about 200ms and then resumes the scan. Looks like "it doesnt understand" what is hearing.
I can provide logs, the unitrunker export, the system export in the Uniden Sentinel or a video of the HP1 doing what I say to be more cleary (I know my english isn't good, sorry for that).
I appreciate any help. Thanks in advance.
Gaston.
Run Unitrunker with a signal receiver on the active control channel.
When the site window appears, check the information column on the right side of the window. The heading for this column is "Svc". As calls appear, the "Svc" column will tell you the call's priority 1 to 7 and also whether the call is emergency "E" or protected "P". If you see the letter "P" in this column, the call is encrypted and there is nothing more you can do.
