No Scanner Traffic From LAPD Frequencies
jromeo
Hi:
I recently bought a Uniden BC345CRS. I have programmed a number frequencies associated with the Los Angeles County Sheriff's Department (LASD), which can be found here:
https://www.radioreference.com/apps/db/?ctid=201#cid-109
I get a lot of scanner traffic. However, when trying the same for the Los Angeles Police Department (LAPD), the first 40-50 frequencies found below, all I get is static, white noise, or no noise at all.
Los Angeles Police Department (LAPD) | SCMA
Can anyone suggest what the trouble might be or any change I can make? Thanks.
MFD4305
Ypsilanti, MI
Bad News. . . .
Hi J,
Your scanner is a "non-trunking, non-digital" scanner. Each of the frequencies in the link you posted is used to transmit a digital ['P25'] signal, which your scanner cannot properly receive.
HTH
AA6IO
Cerritos, CA (LA County)
Yes you need a digital scanner. I live in Cerritos and monitor the LAPD quite often. Sounds great on most of the scanners I have lited below.
Steve AA6IO
