Baofeng NO SOUND , baofeng DM32
Azgunguy
Scottsdale, AZ
No RX Group Lists are not required for operation. It just allows you to sit on Parrot and if someone transmits on another TGID from your RX Group List then the DM-32 should play that TGID audio transmission. Per DMR logic, if you then transmit quick enough (under 1 min?) then the DM-32 will jump to that new channel and stay there.
You don't need a RX Group List. If you choose to operate radio like above then you need only one list that is mapped to the channel info. (It wouldn't shock me if there was a bug there...)
I should point out that Radtel's DMR implementation is a little different. Their CPS requires a RX Group List or you won't receive any audio -- period.
AHHHH thank you. That makes more sense. Let me give that a shot and see if it helps. I appreciate it.
