Northern Virginia Incidents
freqhopping
He was wanted in Fairfax along with MD and DE, so I think he'd being going to Fairfax no matter where it ended up.
freqhopping
VSP pursuit, 495 to southbound I-95. Older Volvo with a WV temp tag. Speed about 120.
1905- SB Rt1
1908- Bailout at Prince William Plaza
1910- Driver in custody, still looking for others
1912- Fairfax2 almost on-scene, heading too far south.
Hbright
1905- SB Rt1
Because this was a topic of curiosity for 1748's last chase, today he took the suspect in the pursuit that started in Fairfax Co but who was apprehended in Prince William Co to Fairfax Co.
Should be noted the suspect is a juvenile so that might change procedures.
freqhopping
Loudoun is currently working a critical missing teen event in the Ashburn area. Day shift kept on to search. Drones in use and Fairfax2 arrived recently.
16 y/o Asian male, 5'5" 125lb, wearing dark blue or black hoodie, eye glasses.
Hbright
VSP is also assisting, Trooper K9 1786 is tracking. Fairfax 2 first said they were given "Dulles TA 2" as the channel, which they couldn't get. Are you aware of a "TA 2" (talk around?) or did they mean Dulles Tac 2 (which is encrypted and would explain why couldn't access that channel)?
Also, are you aware of "K9-46?" Is that an LCSO unit? I thought the 327xxxx RIDs were VSP?
freqhopping
They were talking about Tac 2, TA 2 might be how it's tagged in the Fairfax radio. I heard that too, ENC not so good when it comes to interop.
K9-46 isn't LCSO. I believe LCSO has less than 10 units.
Hbright
"T2" is actually how the Tac 2s are listed on their radios, but maybe that was lost in translation between the LCSO Sgt, ECC, DPSC, and the hanger. Of note, it's also listed as not encrypted so maybe that was their issue?
I also noticed a 326xxxx RID on Dulles Tac 2, maybe LPD is assisting too?
freqhopping
VSP's nightly pursuit of a Charger is occurring currently. Fairfax helo is following overhead. They've been on/around 495 and mixing bowl area. I think there were several other pursuits earlier in the night. Heard the helo helping out and nabbing someone, then a brief motorcycle pursuit and possibly some others.
0316- Exited 395 to Glebe, straight across, then bailed out. VSP has the driver and one passenger, may be one other that ran.
0335- VIN comes back as stolen.
weyforthr
Stafford Virginia
Fairfax 2 Helo did a great job of coordinating an earlier pursuit around 2030 Thursday evening. The relatively high speed pursuit included an PIT maneuver and at least one K-9 unit. This incident shows how professionally (Fairfax 1) VSP operates. I have audio from that chase and it is worthy of a second listen. There is a particular FFX1 Dispatcher that is a super professional at her job.
Hbright
Yes, Fairfax 2 was able to simulcast across VSP channels (FRFX 1 and 2 patched) and FCPD channel 7. Helpful to get info quickly to officers from both agencies.
The brief motorcycle pursuit was terminated by order of the Sgt as it was off the interstate.
freqhopping
VSP in pursuit on the Beltway in the area of Braddock Rd. At least five troopers involved at this point as seen on traffic cams.
0048- To Rt50 westbound
0049- Crashed at Williams Dr after doing a U-turn then hitting a trooper head-on as he was also turning around. Doesn't make much sense but that's what he said.
Stolen vehicle
freqhopping
The plane is now being transported north on Rt606 so the southbound is back to moving but northbound will be held up because the tow truck is moving slow.
freqhopping
VSP in pursuit on the Beltway outer, passing Rt50. Speed of 130ish.
Reason for initial stop- loud exhaust and fictitious tag.
2359- Terminated at the river. Silver BMW with a WY truck tag. Never really got close to it once it took off.
freqhopping
Must've missed a pursuit earlier. VSP now heading to a Franconia location for someone likely falsely reporting a carjacking.
Now sounds like the owner crashed and ran away on foot, but is blaming it on a carjacker.
freqhopping
Now an unrelated pursuit of a Dodge Durango, heading east on the Beltway from Eisenhower.
Terminated at the bridge as usual. Asked to notify PG Co and not to bother notifying MSP. I guess MSP is worthless since this seems to be a nightly occurrence.
