Northstar 990v frequency jumping.
Caveman195
Indiana
Just got ahold of a Northstar 990v from a truck driver. Hooked it up and have low to no receive and the frequency counter continuously runs up a few mhz and down a few mhz. On channel 19 its showing I'm in the 30.xxxmhz range so I know that's incorrect. I have found that there's possibly an issue at the microphone plug on the radio. Any idea if this is my issue or if I have something else causing this issue?
WSAC829
Mike Oscar 225
EN64ak
That radio was supposed to be a clone of the Galaxy DX99v. However, Northstar cheaped out and used a PIC IC and rotary encoder to generate the PLL codes which tended to wear out and fail. Some guys used to replace the failed 8 Mhz PIC clock crystal with a 7.8 Mhz crystal from a Cobra 148 GTL to fix it. You’ll need to have a good radio shop or local tech look at it. Otherwise you purchased a 25 year old shiny paperweight unfortunately.
Caveman195
Indiana
Well luckily it was given to me by a truck driver at work. Wonder what the cost will be for repairs?
WSAC829
Mike Oscar 225
EN64ak
Free is good, but you can buy far better radios with all the same features and more new for roughly $175-$300, i wouldn’t put more than $75 in to that radio. The parts wouldn't cost much, but the shops labor rate is where it might get expensive. It’s old dated technology, and was already a cheap “knock off” to begin with.
slowmover
Fort Worth
I wouldn’t spend on it. Info almost doesn’t exist and it’s far too old, IMO.
It’s a nice intro having been given a radio. An old radio is itself not a bad thing where a minor repair gets it going.
I normally only recommend an AM/SSB radio. But the one linked will get you going. Same for antenna. Check around on prices.
The take-no-baby-steps and go straight to high performance route. This performance was 2X more expensive just a few years ago:
Indiana and the Midwest is a great place to have an excellent Citizen Band radio compared to much of the country.
Welcome to RR!
